Ezviz Full HD WiFi Indoor/Outdoor Wire - Free Battery Cam and 4G LTE Hub with Built-in Siren
Quicklinx: F8ZGWS00 Mfr#: CS-WLB-B1-EUP(O-STD)
  • microSDHC Card
  • microSD Card
Introducing the EZVIZ Wi-Fi Battery Camera & 4G LTE Hub
The EZVIZ Battery Camera is a weatherproof indoor/outdoor standalone 100% wire-free, battery-powered security camera. It enables the user to effortlessly and seamlessly place it anywhere without any hassles of dealing with cables.
The EZVIZ 4G Hub prolongs the battery life of an EZVIZ wire-free camera by up to 9 months. (Work Condition: Normal temperature and environment, triggered 5min/Day). The Hub Works with up to six EZVIZ wire-free Battery cameras
Two additional unique features of the 4G Hub is that it can also act as a Wi-Fi Router to up to two other Wi-Fi Devices around the home, so if you ever had a powercut you can still operate from home on the Internet. As well as this – your security system will still be in full operation due to the ability to utilise a 4G data sim card (sold separately).
Furthermore, the 4G Hub has a built-in 100db Siren so that when motion is detected you can choose via the EZVIZ app if you want an automatic or manual siren activation to occur.
A wide range of accessories are also available to enhance your EZVIZ wire-free Battery Camera experience, including a solar power panel, charging station, and metal mount for more secure installation.
Rechargeable Battery for EZVIZ wire-free camera
Long Life 5500mAh Rechargeable lithium battery for the wire-free camera that can last up to 3 months on its own, but when used with the EZVIZ 4G Hub, battery life can be prolonged up to 9 months. In both instances this is subject to your environmental conditions and usage levels.
Smart Human Detection & Instant Alerts
Featuring PIR human detection, the wire-free camera sends an instant alert to you when a human is approaching. With two-way audio you can also communicate via the EZVIZ app.
HD Video with Wide-Angle View & Night Vision
With its HD 1080p wide-angle lens, the battery camera gives you a convenient 126 degrees’ view. The wire-free camera also features up to 5 meters of night vision and delivers crystal clear images even at night. The video switches between day and night modes automatically.
Designed for All Conditions
The EZVIZ wire-free camera comes with clear, 5m night vision and an IP65 weatherproof design.
One App Does All the Work
All you need to do for setup is follow the instructions via the free EZVIZ app and your home Wi-Fi. The EZVIZ app works with all EZVIZ Cameras and alarm products. View and manage remotely wherever you are.
Storage of footage
EZVIZ cameras can hold a MicroSD card for local and continuous storage, alternatively you can sign up to our Cloud Storage system (subject to subscription) or via an EZVIZ Network Video Recorder (NVR).
Further Recommendations Consider a Wi-Fi Range Extender if you have poor connectivity around the home from your Router location
Works with Amazon Alexa, Google Assistant & EZVIZ Alarm Systems
EZVIZ C3A - network surveillance camera - with EZVIZ WLB base station
Network surveillance camera - fixed - outdoor, indoor - dustproof / weatherproof
Bundled with
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
5.608 cm x 7.002 cm x 9.209 cm
215 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
CMOS - 1/4" - 2 MP
Focal Length Control
Fixed focal
Focal Length
2.2 mm
Lens Iris
F/2.4
Wi-Fi
Voltage
DC 5 V
Saturation control, brightness control, contrast control, image mirror, automatic electronic shutter, Motion Detection Technology, infrared cut filter, Digital Wide Dynamic Range (D-WDR), dual video stream, password protection, flickerless, Variable Bitrate (VBR), cloud recording, 3D Digital Noise Reduction Technology
Environmental Parameters (operating)
-20 °C - 45 °C; 0 - 95% (non-condensing) relative humidity
Audio Support
Wireless
5.608 cm
7.002 cm
9.209 cm
215 g
Europe
Bundled with
Camera
Colour - Day&Night - fixed - outdoor, indoor - dustproof / weatherproof
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Infrared LEDs
Infrared Distance
7.5 m
Digital Video Capture Resolution
1920 x 1080
Frame Rate (max)
Image Sensor
2 MP CMOS 1/4"
Lens Construction
Fixed focal
Focal Length
2.2 mm
Lens Iris
F/2.4
Horizontal Field of View (degree)
126
Network Interface
Wi-Fi
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
IP65
Power Requirements
DC 5 V - 1.5 A
Power adapter - external 5 Watt
Lithium Ion 5500 mAh
-20 °C
45 °C
Relative Humidity (operating)
