Ezviz Full HD Indoor Smart Security PT Cam, with Motion Tracking
Quicklinx: F8Z2WS00 Mfr#: CS-CV248-A0-32WFR
Introducing the EZVIZ Pan and Tilt camera
Imagine that you are at work and an intruder has come into your home – your Pan/Tilt Wi-Fi Smart Camera will alert you straight away with a message via the EZVIZ app to your smartphone, take a snapshot and even proceed to record the events and the suspicious activity. What’s more, the C6Tc will track and follow them too, gathering up as much footage as possible.
Baby/Elderly/Pet Monitor
Great for monitoring your pets, little ones or elderly relatives. Furthermore, with the two-way talk, you can see, hear and speak all through the EZVIZ app, whether you are at home or away!
Pan/Tilt & Motion Tracking
With the 360-degree Horizontal, 80-degree vertical rotation Pan & Tilt feature, you can see everything in the room, keeping a lookout of the whole room. If it notices something moving (like the dog with something in its mouth), the camera will track the movement automatically across the room, providing the best footage possible. This can also be manually moved around via your EZVIZ smartphone app.
Be Informed Motion Detection Alerts will trigger a notification to be sent to your smartphone via the EZVIZ app which brings attention to the event occurring from wherever you are.
Amazon Alexa & Google Home Compatible - Using the sound of your voice you can view live footage via your Amazon Alexa and Google Hub
Secure Your Home Day & Night
The Infrared (IR) allows clear video even when it’s dark, giving clear night vision and recording, providing 24/7 security in your home or office.
Two-way Talk
The internal microphone supports audio pickup within five meters and video recording with sound, meaning you can have a two-way conversation if needed via the EZVIZ app.
Easy Setup
For product setup simply follow the instructions via the EZVIZ app to connect it to your Wi-Fi and complete the setup process.
App Features
With the EZVIZ app you can manage and view your camera live. In addition to this you can set schedules, create detection areas and review/share previous footage.
Storage of footage
EZVIZ cameras can hold a MicroSD card (up to 128GB) for local storage upon each detection, or alternatively you can sign up to our Cloud Storage system (subject to subscription costs)
Works with EZVIZ Alarm Systems
Link to a specific EZVIZ alarm sensor via the app to ensure footage begins straight away when a sensor is triggered. Furthermore, one set via the app, the Pan/Tilt feature will automatically move direction towards the sensor in question helping capture the whole event from all angles.
What’s in the box
  • 1x EZVIZ HD 1080p Pan Tilt Camera
  • 1x Power Adapter with 3m Cable (3.5mm jack connection)
  • 1x Mounting Accessories and set of screws
  • 1x Quick Start Guide
  • Clearer, sharper video
    All glass lenses. High-quality sensors. Amazing image quality. The C6T delivers clear high-definition 1080p video, rich colors, and sharp details.
  • See the whole room
    The beauty of this incredible HD pan and tilt camera is that you can place it where you want and still see the whole room. All you have to do is take out your phone and press a button for a better view.
  • Privacy mask
    Sometimes you want a little alone time. Don't worry. With just a tap, the lens rolls up for complete privacy.
  • Pan and tilt
    The C6T already covers quite a bit of any room. It has a 92° viewing angle, after all. But with pan and tilt, you can see everything in the room. Just pull out your phone and use the EZVIZ app.
  • Night vision
    What good is a camera that only works during the day? The C6T delivers and incredible night vision range when it's dark - large enough to cover just about any room.
  • Two-way talk
    For those times when you're away from home and the dog is digging through the trash, there's two-way talk. Just press the button on the EZVIZ app and let the camera's built-in speaker and mic help you do the rest.
EZVIZ C6T - network surveillance camera
Network surveillance camera - pan / tilt - indoor
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
10 cm x 10 cm x 9 cm
220 g
White
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
720/30p, 1080/15p
Optical Sensor Type
CMOS - 1/3" - 2 MP
Minimum Illumination
0.02 lux F2.0 - AGC on , 0 lux - IR
Focal Length Control
Fixed focal
Focal Length
4 mm
Lens Mounting
M12 mount
Lens Iris
F/2.0
Panning Range (degree)
0 to 340
Tilting Range (degree)
-10 to +80
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 5 V
Backlight Compensation (BLC), alarm function, progressive scanning, saturation control, brightness control, contrast control, image mirror, Motion Detection Technology, infrared cut filter, Privacy Mask Function, Digital Wide Dynamic Range (D-WDR), Wi-Fi Protected Setup (WPS), Dual Stream Encoding, microSDXC card slot, password protection, auto tracking, Smartphone Monitoring, Variable Bitrate (VBR), cloud recording, 3D Digital Noise Reduction Technology, WPA, WPA2-PSK, 64-bit WEP, 128-bit WEP, WPA-PSK, WPA2, watermark, heartbeat, anti-flicker
1-year warranty
Environmental Parameters (operating)
-10 °C - 55 °C; 0 - 95% (non-condensing) relative humidity
Audio Support
Wired, wireless
10 cm
10 cm
9 cm
220 g
Camera
Colour - Day&Night - pan / tilt - indoor
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
720/30p, 1080/15p
Exposure Range
1/30 sec - 1/100000 sec
Infrared LEDs
Infrared Distance
10 m
Video Capture
1920 x 1080 @ 15 fps , 1280 x 720 @ 30 fps
Image Sensor
2 MP CMOS 1/3"
Lens Construction
M12 mount - fixed focal
Focal Length
4 mm
Lens Iris
F/2.0
Horizontal Field of View (degree)
92
Panning
Range (degree)
0 to 340
Tilting
Range (degree)
-10 to +80
Network Interface
Ports
LAN - RJ-45
Supported Memory Cards
microSDXC Card
Camera mount base, screw kit, drill hole template
White
Power Requirements
DC 5 V
Power adapter - external 6 Watt
Limited warranty - 1 year
-10 °C
55 °C
Relative Humidity (operating)
