Ezviz Full HD Indoor Smart Security Cam
Quicklinx: H0RWWS00 Mfr#: CS-C1C-E0-1E2WF
  • microSDHC Card
  • microSD Card
The C1C-B, a compact Wi-Fi camera from EZVIZ, records sweet moments, protects your family, and keeps you updated on what's happening at home when you're away. It's small enough to be placed almost anywhere, and its simple DIY installation design lets you easily configure this camera for better performance.
  • Clarity as always
    This camera performs brilliantly regardless of hourly changes in light and shadow. Advanced, built-in infrared LEDs ensure a 12-meter Full HD night vision range, helping you capture incredible low-light shots without creating light pollution.
  • User-friendly audio alerts
    This camera also comes with three audio alert modes when motion is detected - silent, short beep, and siren. Want to hear your visitors while you are in another room? Set the camera on siren mode so you will hear the alert loud and clear.
  • Records only when you want it to
    The C1C-B camera provides a flexible option for you to record - or not - whenever you think it's necessary.
  • Two-way audio
    With the C1C-B, you can talk to your child, pet or other family members right on your phone while you're away.
  • Compact and thoughtful design
    A magnetic base and clever mounting kit make installation a breeze. Mount this camera by attaching it to any magnetic surface, or use the kit to attach it to a wall or ceiling - and you are all set. Its upgraded positioning stem on the base also makes it more flexible - so you get the exact viewing angle that you need.
  • H.265 video technology
    The camera features the advanced H.265 video compression technology, achieving better video quality using only half the bandwidth and half the storage space of the previous video compression standard (H.264).
EZVIZ C1C-B - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: two-way audio capability
6.3 cm x 6.3 cm x 10.3 cm
83 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
25 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
PS CMOS - 1/3"
Minimum Illumination
0.5 lux F2.2 - AGC on , 0 lux - IR
Focal Length Control
Fixed focal
Focal Length
2.8 mm
Lens Mounting
M12 mount
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 - USB cable - external
Voltage
DC 5 V
Progressive scanning, image mirror, infrared cut filter, dual video stream, password protection, Smartphone Monitoring, built-in siren, audible alerts, cloud recording, magnetic mount, WPA, WPA2-PSK, 64-bit WEP, 128-bit WEP, WPA-PSK, WPA2, watermark, heartbeat, anti-flicker, 3D digital noise reduction (DNR), self-adaptive shutter, instant notification, Adaptive Bitrate (ABR)
Environmental Parameters (operating)
-10 °C - 45 °C; 0 - 95% (non-condensing) relative humidity
Audio Support
Wireless
6.3 cm
6.3 cm
10.3 cm
83 g
Camera
Colour - Day&Night - fixed
Digital Video Format
H.265
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Digital Zoom
8
Infrared LEDs
Infrared Distance
12 m
Digital Video Capture Resolution
1920 x 1080
Frame Rate (max)
Image Sensor
PS CMOS 1/3"
Lens Construction
M12 mount - fixed focal
Focal Length
2.8 mm
Horizontal Field of View (degree)
91
Vertical Field of View (degree)
50
Diagonal Field of View (degree)
108
Network Interface
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Foam sticker, metal wall mount plate
1 x USB cable - external
UL, FCC, RoHS, AES-128, WEEE, REACH, TLS
Power Requirements
DC 5 V - 1 A
Power adapter - external 3 Watt
Shipping Width
9.15 cm
Shipping Depth
8.75 cm
Shipping Height
14.9 cm
Shipping Weight
310 g
-10 °C
45 °C
Relative Humidity (operating)
