The C6N from EZVIZ comes equipped with a Smart IR function, which uses advanced infrared (IR) lighting to capture more details in dim light. With its 360-degree field of view and smart tracking function, you won't need to worry about missing a thing.
Smart night vision with Smart IR
With Smart IR, the intensity of the infrared LEDs automatically adjusts to prevent overexposure in night vision mode, so you will get more details of the object or person captured at night. -
Zero blind spots
Keep tabs on every corner with just one C6N. Its expansive 360-degree field-of-view ensures full coverage, so you don't miss a thing. -
Smart tracking
When it detects a moving object, the C6N is smart enough to automatically track its motion while alerting you with an image in real-time. -
Communication anytime
Talk to your loved ones and deter unwelcome strangers - all by using the C6N's two-way communication feature. Using the EZVIZ App on your mobile device, you can easily and conveniently enjoy communication wherever you might be. -
Protects your privacy
Want a bit more privacy? With one tap of the EZVIZ App on your mobile device, you can enable C6N's sleep mode, giving you privacy when you need it.
- EZVIZ C6N 4MP - network surveillance camera
- Network surveillance camera - pan / tilt
- Audio
- Yes: two-way audio capability, built-in microphone, built-in speaker
- 8.8 cm x 8.82 cm x 11.9 cm
- 252 g
- Connectivity Technology
- Wireless, wired
- Camera
- Colour - Day&Night
- Max Resolution
- 2560 x 1440
- Frame Rate (max)
- 20 frames per second
- Motion Detection
- Video Modes
- 1080p
- Optical Sensor Type
- PS CMOS - 1/3" - 4 MP
- Focal Length Control
- Fixed focal
- Focal Length
- 4 mm
- Lens Mounting
- M12 mount
- Lens Iris
- F/2.4
- Panning Range (degree)
- 350
- Tilting Range (degree)
- 55
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Ethernet 10Base-T/100Base-TX
- Voltage
- DC 5 V
- Smart IR, smart tracking, Smartphone Monitoring, cloud recording, instant notification, self-adaptive shutter, infrared cut filter, 3D digital noise reduction (DNR), Digital Wide Dynamic Range (D-WDR), Adaptive Bitrate (ABR), 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA2-PSK, WPA-PSK, progressive scanning, reset button
- 2-year warranty
- Environmental Parameters (operating)
- -10 °C - 45 °C; 0 - 95% (non-condensing) relative humidity
- Audio Support
- Wireless, wired
- 8.8 cm
- 8.82 cm
- 11.9 cm
- 252 g
Camera
- Colour - Day&Night - pan / tilt
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 2560 x 1440
- Motion Detection
- Video Modes
- 1080p
- Digital Zoom
- 4
- Infrared LEDs
- Infrared Distance
- 10 m
- Digital Video Capture Resolution
- 2560 x 1440
- Frame Rate (max)
Image Sensor
- 4 MP PS CMOS 1/3"
Lens Construction
- M12 mount - fixed focal
- Focal Length
- 4 mm
- Lens Iris
- F/2.4
- Horizontal Field of View (degree)
- 85
- Vertical Field of View (degree)
- 55
- Diagonal Field of View (degree)
- 124
Panning
- Range (degree)
- 350
Tilting
- Range (degree)
- 55
- Network Interface
- Ports
- LAN - RJ-45
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- Included Accessories
- Camera mount base, screw kit, drill hole template
- FCC, UL, WEEE, REACH, RoHS
- Power Requirements
- DC 5 V - 2 A
- Power Device
- Power adapter - external 5 Watt
- Limited warranty - 2 years
- Shipping Width
- 10.3 cm
- Shipping Depth
- 10.3 cm
- Shipping Height
- 16.8 cm
- -10 °C
- 45 °C
- Relative Humidity (operating)
- 0 - 95% (non-condensing)
