Ezviz Full HD Indoor/Outdoor Battery Cam
Quicklinx: F8ZBWS00 Mfr#: CS-C3A-A0-1C2WPMFBR
  • microSDHC Card
  • microSD Card
Introducing the EZVIZ Full HD Wire-free Battery Camera
This EZVIZ camera is a weatherproof indoor/outdoor standalone 100% wire-free, battery-powered security camera with 126 Degrees viewing angle. Being wire-free enables you to effortlessly place the camera anywhere without any cables. Furthermore, no hub is required.
Be Informed
Featuring PIR technology to help reduce false triggers, it simply detects heat sources only, such as Cars, Animals and Humans. Motion Detection Alerts will trigger a notification to be sent to your smartphone via the EZVIZ app which brings attention to the event occurring from wherever you are.
Baby/Elderly/Pet Monitor
Great for monitoring your pets, little ones or elderly relatives. Furthermore, with the two-way talk, you can see, hear and speak all through the EZVIZ app, whether you are at home or away!
Continuous wire-free recording
With a long-lasting 5,500mAh rechargeable battery that will last up to 2 months before having to charge, you can have peace of mind knowing that you will always be covered. Also great for wildlife monitoring e.g. Bird Boxes.
Amazon Alexa & Google Home Compatible
Using the sound of your voice you can view live footage via your Amazon Alexa and Google Hub
24/7 All Season Protection
Because of its IP65 enclosure rating, the Outdoor camera will be resistant against rain, snow, and other weather conditions. With the integration of Infrared technology, footage can be seen clearly at Night too. Consider a Wi-Fi Range Extender for further connectivity
Two-way Talk
The internal waterproof microphone supports audio pickup within five meters and video recording with sound, meaning you can have a two-way conversation if needed via the EZVIZ app.
Easy Setup
Straight Forward installation with magnetic mount in the box, great for both ceiling and wall-mounted installation. For product setup simply follow the instructions via the EZVIZ app to connect it to your Wi-Fi and complete the setup process.
App Features
With the EZVIZ app you can manage and view your camera live. In addition to this you can set schedules, create detection areas and review/share previous footage.
Storage of footage
EZVIZ cameras can hold a MicroSD card (up to 128GB) for local storage upon each detection, or alternatively you can sign up to our Cloud Storage system (subject to subscription costs)
Further Recommendations Consider a Wi-Fi Range Extender if you have poor connectivity around the home from your Router location
What’s in the box
  • 1x EZVIZ Full HD Wi-Fi Outdoor Smart Home Security Camera
  • 1x Power Adapter with 3 metre cable
  • 1x 5,500mAh Battery
  • 1x Magnetic Mount
  • 1x Quick Start Guide
EZVIZ C3A - network surveillance camera
Network surveillance camera - fixed - outdoor, indoor - dustproof / weatherproof
Audio
Yes: built-in speaker, built-in microphone
Wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
CMOS - 1/4" - 2 MP
Focal Length Control
Fixed focal
Focal Length
2.2 mm
Lens Iris
F/2.4
Wi-Fi
1 - USB cable - external
Voltage
DC 5 V
Saturation control, brightness control, contrast control, image mirror, automatic electronic shutter, Motion Detection Technology, infrared cut filter, Digital Wide Dynamic Range (D-WDR), dual video stream, password protection, flickerless, Variable Bitrate (VBR), cloud recording, 3D Digital Noise Reduction Technology
Environmental Parameters (operating)
-25 °C - 45 °C; 0 - 95% (non-condensing) relative humidity
Audio Support
Wireless
Camera
Colour - Day&Night - fixed - outdoor, indoor - dustproof / weatherproof
Digital Video Format
H.264
Max Digital Video Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Infrared LEDs
Infrared Distance
7.5 m
Digital Video Capture Resolution
1920 x 1080
Frame Rate (max)
Image Sensor
2 MP CMOS 1/4"
Lens Construction
Fixed focal
Focal Length
2.2 mm
Lens Iris
F/2.4
Horizontal Field of View (degree)
126
Network Interface
Wi-Fi
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card
Mounting kit, 10 power connector adapters
1 x USB cable - external
IP65
Power Requirements
DC 5 V - 1.5 A
Power adapter - external
Lithium Ion 5500 mAh
-25 °C
45 °C
Relative Humidity (operating)
