Enjoy high-quality video chat with visitors and keep an eye on what's happening at your front door right through your phone. The DB1C is a powerful video doorbell with built-in artificial intelligence capability.
See every detail you need to see
The DB1C delivers 1080p video, bringing the rich precision and extraordinary images you would expect from EZVIZ. -
Person-detection enabled
With its AI algorithm onboard, the DB1C intelligently detects a person's movement, ensuring that you only receive notifications when people move by. You can turn off this function if you need other motion alerts such as those triggered by animals or cars. -
Covers every inch, from head to toe
Featuring a 170-degree vertical view, the DB1C reliably records everything you need to see. Even a package on the ground will be clearly captured. -
Two-way talk
When the EZVIZ App notifies you of a visitor at the front door, you can see and talk to the person right away, and from wherever you are. -
Dual-band Wi-Fi connectivity
Not all video doorbells support dual-band connectivity. The DB1C does, and it gives you the flexibility to choose between 2.4 or 5GHz connections for optimal performance on your network. -
Save money on storage and bandwidth
The DB1C doorbell features the advanced H.265 video compression technology, achieving better video quality with only half the bandwidth and half the storage space of the older H.264 video compression standard. -
Fearless in any weather
Rated with IP65 protection, the DB1C doorbell works reliably in rain, sleet, or snow, bringing you peace of mind throughout the year. -
Multiple storage solutions
With multiple storage options, you can choose where to save your recordings. The DB1C can even save to all three locations at the same time for added backup in case the camera is damaged, or your network crashes. -
Security at your fingertips
With the EZVIZ App, you can capture, save, protect, and share what's valuable to you.
- EZVIZ DB1C - IP intercom station - 802.11a/b/g/n - with chime transformer
- Product Type
- Functions
- Motion detection, camera
- Integrated Components
- Microphone, speaker
- Bundled with
- Chime transformer
- Connectivity
- Wireless - 802.11a/b/g/n
- Frequency Band
- 2.4 Ghz, 5 GHz
- Camera
- CMOS 1/2.4" - Max Resolution 1536 x 1536 - audio - Day&Night
- 2-year warranty
- 4.63 cm x 1.93 cm x 12.83 cm
- Product Type
- Functions
- Bundled with
- Chime transformer
- Connectivity Technology
- Wireless - IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 Ghz, 5 GHz
- Waterproof, dustproof, reset button, H.264 streaming video, 2-way audio, video intercom, microSD/SDHC/SDXC Memory Card slot, H.265 streaming video
Camera
- Image Sensor
- CMOS - 1/2.4"
- Lens Aperture
- F/2.4
- Focal Length
- 2.1 mm
- Day & Night Functionality
- Audio Support
- Max Digital Video Resolution
- 1536 x 1536
- Infrared cut filter, Digital Wide Dynamic Range (D-WDR), 2-way voice communication, 3D digital noise reduction (DNR), up to 5m night vision distance, 170° field of view (vertical)
- Included Accessories
- Mounting plates, power kit, screwdriver, mounting screws
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- Nominal Voltage
- AC 12 - 24 V
- Warranty
- 2-year warranty
- UL, FCC, RoHS, WEEE, REACH, IP65
- 4.63 cm
- 1.93 cm
- 12.83 cm
- 102 g
- Shipping Width
- 10.2 cm
- Shipping Depth
- 9.7 cm
- Shipping Height
- 17.25 cm
- -30 °C
- 60 °C
- 0 - 95% (non-condensing)
