A camera small in size, but big on functionality. With on-camera AI, the C6 2K? identifies humans and pets in an instant, and detects abnormal sounds to add an extra layer of protection. Its impressive video and audio quality delivers leading performance. Enhance your home and be there for your loved ones with the joy and confidence that the C6 offers.
Impressive video quality in 2K?
The C6 camera excels at seeing everything clearly and vividly. It renders every detail in sharp 2K? resolution, effectively reduces image overexposures, and provides color imaging in extremely low-light conditions. -
Smart enough to detect, zoom, and follow
The camera can automatically zoom in up to four times to follow a moving object so you see details and get the whole picture at the same time. You can always enable the AI option to detect and track specifically human movements. -
Know how your furry friends spend their day
Away at work but do not want to miss an "aww" moment? You can receive mobile notifications whenever your pet is detected by the camera. Even when they are jumping and running, the C6 captures them clearly. -
Notifies you when you're needed
The camera alerts you if the noise level suddenly changes - whether your baby cries or a siren breaks out. Your family members can also simply wave at the camera to initiate a video call to your phone. -
Surprisingly good audio experience
Communications are the basis of companionship, so EZVIZ made the audio quality better than you'd expect. -
Steady connection for boosted performance
Set up the camera network, either wired or wirelessly. You can connect the camera to either 2.4 or 5 GHz band to ensure a strong Wi-Fi signal.
- EZVIZ C6 - network surveillance camera
- Network surveillance camera - pan / tilt
- Audio
- Yes: built-in speaker, two-way audio capability, built-in microphone
- 10 cm x 10 cm x 9.65 cm
- 325 g
- Connectivity Technology
- Wired, wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 2560 x 1440
- Motion Detection
- Video Modes
- 2K
- Optical Sensor Type
- CMOS - 1/3"
- Minimum Illumination
- 0.1 lux - colour - F1.6 - AGC on , 0 lux - IR
- Focal Length Control
- Fixed focal
- Focal Length
- 4 mm
- Lens Mounting
- M12 mount
- Panning Range (degree)
- 353
- Tilting Range (degree)
- 133
- Ethernet 10Base-T/100Base-TX, IEEE 802.11a, IEEE 802.11ac, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Voltage
- DC 5 V
- Backlight Compensation (BLC), progressive scanning, saturation control, brightness control, contrast control, image mirror, 3D digital noise reduction (DNR), Digital Wide Dynamic Range (D-WDR), WPA, WPA2-PSK, 64-bit WEP, 128-bit WEP, WPA-PSK, WPA2, watermark, Auto-Zoom Tracking, Person Detection
- 1-year warranty
- Environmental Parameters (operating)
- -30 °C - 60 °C; 0 - 95% (non-condensing) relative humidity
- Audio Support
- Wired, wireless
- 10 cm
- 10 cm
- 9.65 cm
- 325 g
Camera
- Colour - Day&Night - pan / tilt
- Digital Video Format
- H.264, H.265
- Max Digital Video Resolution
- 2560 x 1440
- Motion Detection
- Video Modes
- 2K
- Infrared LEDs
- Infrared Distance
- 10 m
Image Sensor
- CMOS 1/3"
Lens Construction
- M12 mount - fixed focal
- Focal Length
- 4 mm
- Horizontal Field of View (degree)
- 79
- Vertical Field of View (degree)
- 42
- Diagonal Field of View (degree)
- 92
Panning
- Range (degree)
- 353
Tilting
- Range (degree)
- 133
- Network Interface
- Ports
- LAN - RJ-45
- Supported Memory Cards
- microSD Card
- Included Accessories
- Camera mount base, screw kit, drill hole template
- UL, NOM, IC, FCC, RoHS, WEEE, REACH
- Power Requirements
- DC 5 V
- Power Device
- Power adapter - external 8 Watt
- Limited warranty - 1 year
- Shipping Width
- 11.6 cm
- Shipping Depth
- 11.6 cm
- Shipping Height
- 16.4 cm
- Shipping Weight
- 641 g
- -30 °C
- 60 °C
- Relative Humidity (operating)
- 0 - 95% (non-condensing)
