The C3TN Color covers almost every essential function you could ask for a home security camera. 1080p video quality, color night vision, active defense, IP67 weatherproof design and more, are all packaged in one, simple device. Live safer and smarter with the easy control and reliable performance that the C3TN Color offers.
Vivid images, from day to night
Enjoy great 1080p video quality to see details clearly. With two built-in spotlights, the C3TN Color can illuminate the surroundings at night to capture activities in vivid color. -
Far-reaching night vision for wider protection
The camera makes sure that no one can easily sneak in under the cover of darkness. It renders color night vision up to 15 meters and infrared black-and-white vision up to 30 meters. -
Stands up to even extreme weather
With an IP67-rated camera body, the C3TN Color is both dust- and water-resistant. It can stand steady even against the toughest weather conditions - whether it's rainy, stormy or snowy. -
Keeps you in the know
Want to know what's happening when you're not at home? Watch the live stream with a simple tap on your smartphone using the EZVIZ App. What's better, you will receive a mobile alert as soon as the camera detects motion. -
It's your eyes - and ears
The C3TN Color comes with a built-in noise-canceling microphone, which can pick up clear audio in the surrounding area. You can see and hear what's going on in your backyard or at your front door at any time.
- EZVIZ C3TN - network surveillance camera - bullet
- Network surveillance camera - fixed - bullet - weatherproof
- Audio
- Yes: built-in microphone
- 7.2 cm x 15.2 cm x 7.2 cm
- 256 g
- White
- Connectivity Technology
- Wireless, wired
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Motion Detection
- Video Modes
- 1080p
- Optical Sensor Type
- PS CMOS - 1/2.7"
- Minimum Illumination
- 0.01 lux F2.0 - AGC on , 0 lux - IR
- Focal Length Control
- Fixed focal
- Focal Length
- 2.8 mm
- Lens Mounting
- M12 mount
- Lens Iris
- F/2.0
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Ethernet 10Base-T/100Base-TX
- Voltage
- DC 12 V
- Colour Night Vision, strobe light alarm, cloud recording, noise-cancellation, self-adaptive shutter, 3D digital noise reduction (DNR), Digital Wide Dynamic Range (D-WDR), Adaptive Bitrate (ABR), anti-flicker, dual video stream, heartbeat, image mirror, password protection, watermark, 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA2-PSK, WPA-PSK
- 2-year warranty
- Environmental Parameters (operating)
- -20 °C - 50 °C; 0 - 95% (non-condensing) relative humidity
- Audio Support
- Form Factor
- Bullet
- Wireless, wired
- 7.2 cm
- 15.2 cm
- 7.2 cm
- 256 g
Camera
- Colour - Day&Night - fixed - weatherproof
- Digital Video Format
- H.264, H.265
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Infrared LEDs
- Infrared Distance
- 30 m
- Digital Video Capture Resolution
- 1920 x 1080
- Frame Rate (max)
Image Sensor
- PS CMOS 1/2.7"
Lens Construction
- M12 mount - fixed focal
- Focal Length
- 2.8 mm
- Lens Iris
- F/2.0
- Horizontal Field of View (degree)
- 106
- Diagonal Field of View (degree)
- 122
- Network Interface
- Network Protocols
- TLS
- Ports
- LAN - RJ-45
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- Included Accessories
- Screw kit, waterproof kit, mounting template
- IP67, AES-128, TLS, UL, FCC, WEEE, REACH, RoHS, UKCA
- White
- Power Requirements
- DC 12 V - 1 A
- Power Device
- Power adapter - external 6 Watt
Internet of Things (IoT)
- Supported Host Device Platform
- Android, iOS
- Limited warranty - 2 years
- Shipping Width
- 22.7 cm
- Shipping Depth
- 10 cm
- Shipping Height
- 9.2 cm
- Shipping Weight
- 500 g
- -20 °C
- 50 °C
- Relative Humidity (operating)
- 0 - 95% (non-condensing)
