Introducing the EZVIZ Indoor Full HD Camera
This starter camera is an ideal option to begin your experience with Smart Home Camera technology. The Indoor camera makes it easy to keep an eye on what’s happening in any room. Its magnetic base quickly clamps to any magnetic surface for easy setup if required. Once placed, you can adjust where the camera is aiming by simply moving it with your hand.
Baby/Elderly/Pet Monitor
Great for monitoring your pets, little ones or elderly relatives. Furthermore, with the two-way talk, you can see, hear and speak all through the EZVIZ app, whether you are at home or away!
Be Informed
Motion Detection Alerts will trigger a notification to be sent to your smartphone via the EZVIZ app which brings attention to the event occurring from wherever you are.
Amazon Alexa & Google Home Compatible
Using the sound of your voice you can view live footage via your Amazon Alexa and Google Hub
Secure Your Home Day & Night
Integrated Infrared technology for clear video even when it’s dark, giving clear night vision and recording, providing 24/7 security in your home or office.
Two-way Talk
The internal microphone supports audio pickup within five meters and video recording with sound, meaning you can have a two-way conversation if needed via the EZVIZ app.
Easy Setup
For product setup simply follow the instructions via the EZVIZ app to connect it to your Wi-Fi and complete the setup process.
App Features
With the EZVIZ app you can manage and view your camera live. In addition to this you can set schedules, create detection areas and review/share previous footage.
Storage of footage
EZVIZ cameras can hold a MicroSD card (up to 256GB) for local continuous storage upon each detection, or alternatively you can sign up to our Cloud Storage system (subject to subscription costs)
Continuous Recording Feature
With a MicroSD card storage option, you can now choose the option of continuous recording within the app for this camera, meaning you will have constant monitoring as well as just motion detection recording.
What’s in the box
- 1x EZVIZ Full HD WiFi Indoor Camera
- 1x Power Adapter with 3m Cable (3.5mm jack connection)
- 1x Quick Start Guide
- EZVIZ C1C - network surveillance camera
- Network surveillance camera - fixed
- Audio
- Yes: built-in speaker, two-way audio capability, built-in microphone
- 6.4 cm x 6.4 cm x 10.3 cm
- 96 g
- Connectivity Technology
- Wireless
- Camera
- Colour - Day&Night
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 20 frames per second
- Motion Detection
- Video Modes
- 1080p
- Optical Sensor Type
- CMOS - 1/2.9"
- Focal Length Control
- Fixed focal
- Focal Length
- 2.8 mm
- Lens Mounting
- M12 mount
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Cables Included
- 1 - micro-USB cable - 3 m
- Progressive scanning, image mirror, infrared cut filter, Digital Wide Dynamic Range (D-WDR), dual video stream, password protection, WPA, WPA2-PSK, 64-bit WEP, 128-bit WEP, WPA-PSK, WPA2, watermark, heartbeat, anti-flicker, 3D digital noise reduction (DNR), self-adaptive shutter
- Environmental Parameters (operating)
- -10 °C - 45 °C; 0 - 95% (non-condensing) relative humidity
- Audio Support
- Wireless
- 6.4 cm
- 6.4 cm
- 10.3 cm
- 96 g
Camera
- Colour - Day&Night - fixed
- Digital Video Format
- H.264
- Max Digital Video Resolution
- 1920 x 1080
- Motion Detection
- Video Modes
- 1080p
- Digital Zoom
- 8
- Infrared Distance
- 12 m
- Digital Video Capture Resolution
- 1920 x 1080
- Frame Rate (max)
Image Sensor
- CMOS 1/2.9"
Lens Construction
- M12 mount - fixed focal
- Focal Length
- 2.8 mm
- Horizontal Field of View (degree)
- 106
- Diagonal Field of View (degree)
- 130
- Network Interface
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- Included Accessories
- Metal plate, 2 foam stickers
- Cables Included
- 1 x micro-USB cable - 3 m
- UL, FCC, RoHS, WEEE, REACH
- Power Device
- Power adapter 4 Watt
- Shipping Width
- 12.3 cm
- Shipping Depth
- 7.9 cm
- Shipping Height
- 12.55 cm
- -10 °C
- 45 °C
- Relative Humidity (operating)
- 0 - 95% (non-condensing)
