The BC1 wire-free camera delivers well-rounded home protection for up to a full year on one single charge. The BC1 inherits EZVIZ's core technologies of color night vision, two-way talk, active defense, and more, showcasing unparalleled usability in any household.
Year-long protection on a single charge
Equipped with an impressive rechargeable battery, the BC1 can last for up to a year on one full battery charge. -
Vivid night vision
Thanks to two built-in spotlights, the BC1 can render vivid color imaging even in pitch-black darkness. This allows you to see crucial details that would otherwise be lost. -
Motion alerts are more accurate
Integrating a PIR sensor and the person-shape detection algorithm, the BC1 camera is intelligent enough to distinguish persons from other moving objects, keeping you safe while also reducing unwanted notifications. -
A vigilant guard over your property
Users can set specific time frames for detection. Once the camera detects a person-shape, the BC1 will automatically set off a siren and flash two spotlights to let them know they have been detected. -
Customizable voice messages
A thoughtful product by design, the BC1 allows you to create unique voice messages for greeting or deterrence. -
Fast and easy wire-free setup
Featuring a large battery, Wi-Fi connectivity, and a magnetic base, the BC1 camera requires exactly zero professional help in installation. Simply attach the camera to any metallic surface and it is good to go! -
Built to last
The BC1 camera features an IP66 enclosure, offering high levels of protection against dust and water and delivering long-lasting protection in even tougher weather conditions. -
Helps you save money on storage and bandwidth
The BC1 camera features the advanced H.265 video compression technology, achieving better video quality with only half the bandwidth and half the storage space required by the previous H.264 video compression standard.
- EZVIZ BC1-B3 - NVR + camera(s) - wireless (802.11b, 802.11g, 802.11n) - battery powered, AC powered
- System
- NVR + camera(s) - wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n - 2.4 GHz - battery, power adapter
- Camera
- 3 cameras - night vision
- Lens Mount
- M12 mount
- 6.28 cm x 10.476 cm x 6.28 cm
- 1.304 kg
- 1 year
- System
- Network Interface
- Wireless Frequency Band
- 2.4 GHz
- Built-in microphone, motion alerts, infrared cut filter, dustproof, waterproof, 2-way audio, built-in speaker
- Package Content
- NVR, 3 cameras, 3 magnetic mounts, 3 screw bases, camera power adapter, NVR power adapter, 3 mounting plates, 3 drill templates, 3 screw sets
- Software Included (Y)
- EZVIZ App
- Power Source
- Battery, power adapter
- Warranty
- 1 year
Security DVR
- Frame Rate (Record)
- 25 fps, 30 fps
- Image Resolution
- 1920x1080
- Compression Format
- H.265
- Record Events
- Motion detection
- microSD card slot, smartphone support
Cameras
- Quantity
- 3 cameras
- Sensor
- CMOS - 1/2.8" - 1920x1080
- Field of View
- 108° (H), 128° (D)
- Night Vision
- Infrared Distance
- 10 m
- Focal Length
- 2.8 mm
- Lens Mount
- M12 mount
- Voltage
- DC 5 V
- Power Consumption
- 5 Watt
- -20 °C
- 45 °C
- Operating Humidity
- 0-95% (non-condensing)
- IP66
- Other Ports
- RJ-45
- 6.28 cm
- 10.476 cm
- 6.28 cm
- 1.304 kg
- Details
- NVR: 8.197 cm x 8.197 cm x 16.022 cm , Camera: 6.28 cm x 10.476 cm x 6.28 cm
- Shipping Width
- 26 cm
- Shipping Depth
- 21.7 cm
- Shipping Height
- 18 cm
