Know who's there for what, before you open the door. The EZVIZ DB2 is a 100% wire-free doorbell kit that covers all your basic needs for front-door protection and communication. Despite its super easy installation and reliable use in all weathers, the doorbell comes with multiple advanced features including 2K video, extremely wide field-of-view, and smart motion detection.
See in 2K with the DB2 doorbell
No more frustration with pixelated or blurry videos. The DB2 records everything happening at your doorstep in 2K resolution. It also provides 5-meter infrared night vision for 24/7 peace-of-mind. -
A well-thought-out solution in one kit
To make sure you hear the ring even from afar, EZVIZ pairs it with an indoor chime. Even better, the chime helps extend Wi-Fi signal while boosts the network connectivity for the doorbell. While other wireless doorbells may suffer from network issues, you can always count on the stable connection of the DB2. -
Set up in minutes, and use for about 4 months
If you are less than a stellar electrician, this wireless, wire-free and weatherproof DB2 Pro could be your best option - stick it anywhere and enjoy long-lasting performance. -
See ultra-wide to get the whole picture
With a 176-degree viewing angle, you can easily see the postman from head to toe and know where he places your package. The doorbell also comes with several different mounting plates in the package, which can help adjust the angle of installation to optimize the doorbell's vision. -
A smart doorkeeper to keep you in the know
With both human-shape and PIR detection capabilities, the device is smart enough to distinguish people from pets or objects. You can customize the alert trigger conditions to adjust its sensibility. -
Easy to use but hard to tamper with
In case the doorbell is forcibly removed, a sharp alarm will sound and a mobile alert will be instantly sent to you. What's more, the DB2 Pro prohibits unauthorized use after theft, thanks to the account binding restriction. -
Reduce video storage space and ease network loads
The doorbell features the advanced H.265 video compression technology, achieving same or better video quality while reducing required bandwidth and storage space.
- EZVIZ DB2 - doorbell kit - 802.11b/g/n
- Product Type
- Doorbell kit
- Functions
- Motion detection, camera
- Power Source
- Battery, power adapter
- Package Content
- Doorbell, wireless chime unit
- Connectivity
- Wireless - 802.11b/g/n
- Frequency Band
- 2.4 Ghz
- Camera
- CMOS 1/2.7" - Max Resolution 2000 x 1504 - audio - Day&Night
- 2-year warranty
- Product Type
- Doorbell kit
- Functions
- Power Source
- Package Content
- Connectivity Technology
- Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 Ghz
- Tamper alert, H.265 streaming video, H.264 streaming video, 20 selectable ringtones, weatherproof
Camera
- Image Sensor
- CMOS - 1/2.7"
- Lens Aperture
- F/2.0
- Focal Length
- 2 mm
- Day & Night Functionality
- Audio Support
- Max Digital Video Resolution
- 2000 x 1504
- 3D digital noise reduction (DNR), 2D digital noise reduction (DNR), built-in 5200 mAh battery, up to 5m night vision distance, 176° field of view (diagonal), built-in speaker, built-in microphone, human detection, reset button, progressive scanning
Motion Sensor
- Detection Mode
- Passive infrared (PIR)
- Detection Range
- 5 m
- Detection Angle
- 100 degree(s)
Flash Memory
- Supported Flash Memory Cards
- microSD
- Included Accessories
- Screws, mounting plate, sticker, drilling template, connector kit, power cable
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- Warranty
- 2-year warranty
- UL, FCC, RoHS, WEEE, REACH
- Dimensions & Weight Details
- Chime: 5.5 cm x 3.5 cm x 10 cm x 120 g , Doorbell: 5.8 cm x 3.2 cm x 15 cm x 241.35 g
- -20 °C
- 50 °C
- 0 - 95% (non-condensing)
