EVGA SuperNOVA 550 G2 550W Gold Fully Modular PSU
Quicklinx: BHYXWS00 Mfr#: 220-G2-0550-Y3
The unbeatable performance of the SVGA SuperNOVA G2 power supply line is now available in 550 watt. Based on the award winning G2 power supplies, these units feature 80 Plus Gold rated efficiency, and clean, continuous power to every component. The ECO control fan system offers fan modes to provide absolutely zero fan noise during load to medium load operations. Backed by 100% Japanese capacitor design, the SVGA SuperNOVA 550 G2 power supplies offer unbeatable performance at an unbeatable value.
  • Single +12 V rail
    A single +12 V rail offers the best power output, rail stability and compatibility with the hardware.
  • LLC resonant circuit layout
    Full DC to DC, LLC resonant circuit design improves efficiency.
  • Fully modular
    Fully modular designs allows every single cable to be removed from the power supply for ease of installation and removal. You can also leave off unnecessary cables to reduce case clutter and maximize case airflow.
  • Highest quality solid state capacitors
    Get the most reliability and greatest performance with the use of the highest possible quality Japanese solid state capacitors.
  • Double ball bearing fan
    A high-quality dual-ball bearing fan gives the SuperNOVA 550 G2 an excellent thermal and acoustic profile, and its high reliability ensures a long PSU lifetime.
  • Gold rated efficiency
    80 Plus certification ensures your power supply isn't wasting power and turning it into excess heat. Under typical load this power supply is 90% efficient or higher.
EVGA SuperNOVA 550 G2 - power supply - 550 Watt
Power supply - internal
80 PLUS Certification
80 PLUS Gold
2.72 kg
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
550 Watt
Output Current
+3.3V - 22 A , +5V - 22 A , +12V - 45.8 A , +5VSB - 3 A , -12V - 0.5 A
Output connectors
1 x power 24 pin ATX , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 9 x 15 pin Serial ATA power , 3 x 4 PIN internal power , 1 x 4 PIN mini-power connector , 2 x 8 pin PCI Express power with detachable 2 pin section , 1 x 8 pin PCI Express power
Modular Cable Management
Cooling System
140 mm fan
15 cm x 16.5 cm x 8.5 cm
7 years warranty
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
550 Watt
Output Current
Efficiency
90% (115VAC) / 92% (220-240VAC)
80 PLUS Gold
Power cable - external - 1.5 m , Power 24 pin ATX modular cable 60 cm , Power 8 pin EPS12V modular cable 70 cm , 2 x PCI Express power cable , 3 x power 15 pin SATA to 4 pin cable , Floppy adapter , Power cable
MTBF
100,000 hour(s)
Cooling System
140 mm fan
Over current protection, over voltage protection, SLI ready, CrossFire ready, undervoltage protection, short-circuit protection, single 12V rail, dual ball bearing cooling fan, ECO Intelligent Thermal Control System, Eco-Mode, fully modular
BSMI, CB, FCC, RoHS, WEEE, cTUVus, ErP 2013, RCM
Limited warranty - parts and labour - 7 years
50 °C
15 cm
16.5 cm
8.5 cm
2.72 kg
