EVGA 1000W SuperNOVA 1000 G2 ATX 80 PLUS Gold PSU
Quicklinx: 8W9NWS00 Mfr#: 120-G2-1000-XR
The EVGA SuperNOVA 1000 G2 has arrived! This power supply is 80 PLUS Gold rated, offers 1000 W of continuous power, exceptional efficiency and is fully modular. Designed with enthusiast needs in mind the EVGA SuperNOVA 1000 G2 power supply is the best choice to power this and next generation enthusiast computers. Take your system to the next level and power up with the EVGA SuperNOVA 1000 G2!
EVGA SuperNOVA 1000 G2 - power supply - 1000 Watt
Power supply - internal
Specification Compliance
ATX
80 PLUS Certification
80 PLUS Gold
3 kg
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1000 Watt
Output Current
+5V - 20 A , +3.3V - 20 A , +12V - 83.3 A , -12V - 0.5 A , +5VSB - 2.5 A
Output connectors
1 x power 24 pin main output , 2 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 6 x 8 pin PCI Express power with detachable 2 pin section , 2 x 6 pin PCI Express power , 10 x 15 pin Serial ATA power , 5 x 4 PIN internal power , 1 x 4 PIN mini-power connector
Modular Cable Management
15 cm x 20 cm x 8.5 cm
10-year warranty with product registration
ATX
PSU Form Factor
ATX
Input Voltage
AC 100-240 V
Frequency Required
50 - 60 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
1000 Watt
Output Current
Efficiency
90% (115VAC) / 92% (220-240VAC)
80 PLUS Gold
Overheat protection, over current protection, over voltage protection, overpower protection, SLI ready, undervoltage protection, cable management, short-circuit protection, single 12V rail
TUV, C-Tick, BSMI, CB, CCC, FCC, RoHS, cTUVus
Limited warranty - 10 years
50 °C
15 cm
20 cm
8.5 cm
3 kg
