Time-saving features: Prints are delivered quickly and efficiently at up to 34 pages per minute in draft mode, and up to 15 mono and 8.4 colour pages per minute for business-quality documents.
Further boost speed with super-fast A4 double-sided printing at up to 7.7 mono and 5.2 colour pages per minute, while cutting paper usage and costs by up to 50 percent.
Productive: High-capacity 250-sheet paper tray for less frequent refilling and a 30-sheet Automatic Document Feeder for multiple page scanning, copying and faxing at up to A3.
Economical: See savings of up to 50 percent on cost per page compared to competitive lasers. Businesses can also print up to 1,000 pages, equivalent to two reams of paper, with Epson's individual XL Stag inks. ENERGY STAR-qualified reduced power consumption further cuts costs and environmental impact. Up to 80% lower energy consumption than competitive colour lasers and more affordable than the laser equivalent.
Get connected: Share across the entire business with Ethernet or Wi-Fi connectivity with enhanced WPA2 wireless security. The WF-7525 also comes with Epson Connect which offers even more flexibility and freedom, allowing users to quickly and easily print images and documents wirelessly from smartphones and tablet PCs. Additionally, users can print from anywhere in the world by emailing documents and images directly to the printer. Google Cloud Print is also supported.
Furthermore, the WF-7525 is AirPrint Ready which enables users to print emails, photos, web pages and documents directly from an iPad, iPhone and iPod Touch.
Easy to use: A 6.3cm colour LCD screen with accompanying PictBridge, USB flash and memory card slots offer straightforward PC-free printing.
True A3+ all-in-one
A3+ prints with A3 fax, copy, scan. -
Double-sided A4 prints
Reduce paper usage by up to 50% -
Productive
500 sheet paper capacity. -
Flexible
30-sheet A4 duplex ADF. -
Share securely
Ethernet and WiFi connectivity. -
Epson Connect
Print from smartphones and tablet PCs. Email documents to the printer. -
Google Cloud Print
Print on the go from your smartphone or computer. -
Apple Airprint
Print directly from your iOS device.
- Epson WorkForce WF-7525 - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson Micro Piezo - 4-ink
- Max Printing Speed
- Up to 15 ppm (mono) / up to 8.2 ppm (colour)
- Max Printing Resolution
- Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 200 x 200 dpi, 200 x 100 dpi
- Scanning
- 1200 x 1200 dpi
- Original Size
- A3 (297 x 420 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 30 sheets
- Media Size
- A3 plus (311 x 457 mm) (max)
- Media Type
- Envelopes, plain paper
- Standard Media Capacity
- 500 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- Power
- AC 230 V
- 55.9 cm x 41.8 cm x 36.5 cm
- 18.9 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Copier Type
- Digital
- Fax Type
- Plain paper
- Ink-jet - colour
- Interface
Printing
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 384 nozzles (black), 3 x 128 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 2 pl
- Ink Type
- Epson DURABrite Ultra inks
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 180 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 60 station(s)
- Broadcast Transmission
- Yes (black only)
- Colour faxing, group dialling, delayed sending
Document & Media Handling
- Max Original Size
- A3 (297 x 420 mm)
- Original Type
- Sheets
- 30 sheets
- Max Media Size
- A3
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), 100 x 150 mm, A3 plus (329 x 423 mm), 130 x 180 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
- 500 sheets
- 2 x input tray - 250 sheets , ADF - 30 sheets
- Speed Details
- Printing: up to 34 ppm (A4) - B/W , Printing: up to 34 ppm (A4) - colour , Printing: up to 15 ppm (A4) - B/W (ISO/IEC 24734) , Printing: up to 8.2 ppm (A4) - colour (ISO/IEC 24734)
- 1 x USB 2.0 , 1 x USB host , 1 x LAN
- WEP, WPA-PSK, WPA2, TKIP, AES
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.4.11 or later, MS Windows Server 2008, MS Windows Server 2008 R2
- Software Included
- Epson Event Manager, Epson Easy Photo Print, Epson Fax Utility, Presto! PageManager 9
- Voltage Required
- AC 230 V
- 20 Watt
- Power Consumption Sleep
- 4.4 Watt
- Direct Printing Specifications
- PictBridge
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- ENERGY STAR Certified
- Limited warranty - 1 year
- 55.9 cm
- 41.8 cm
- 36.5 cm
- 18.9 kg
