The Epson TM-T88VI PUSB printer is a revolutionary receipt printer with advanced connectivity and cloud support. The printer can connect to multiple devices simultaneously and be dynamically shared by legacy POS terminals, tablets and mobile devices, as well as cloud servers.
- Epson TM-T88VI - receipt printer - B/W - thermal line
- Printer Type
- Receipt printer - thermal line - B/W
- 1.6 kg
- Max Media Size
- Roll (8 cm)
- Max Media Size (Custom)
- 80 mm
- Print Speed
- Up to 350 mm/sec - max speed
- Max Resolution (B&W)
- 180 dpi
- Cutter
- Interface
- LAN, PoweredUSB
- Barcodes
- Code 93, Code 39, QR code, MaxiCode, Aztec code, UPC-A, UPC-E, Codabar, Code 128, PDF417, Data Matrix, GS1 DataBar Omnidirectional, GS1 DataBar Expanded, GS1 DataBar Limited, GS1-128, Composite
- Media Type
- Thermal paper
- Partial-cut cutter
- Networking
- Web server
- Printer Features
- ePOS-Print
- System Requirements
- Linux, Apple MacOS X, Android, Apple iOS, Windows 8.1, Windows 10
- Enclosure Colour
- Black
- 14.5 cm x 19.5 cm x 14.8 cm
- Printer Type
- Receipt printer - thermal line - monochrome
- Enclosure Colour
- Black
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- LAN, PoweredUSB
- 180 dpi
- Auto Cutter
- Barcodes
- Printer Features
- ePOS-Print
Media Handling
- Media Type
- Thermal paper
- Max Media Size
- Roll (8 cm)
- 80 mm
- Media Sizes
- Roll (8 cm)
- Media Thickness Range
- 0.048 mm - 0.08 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (8 cm)
- Networking
- Web server
- WEP, WPA-PSK, WPA2-PSK, EAP-TLS, PEAP, MS-CHAPv2
- Connections
- 1 x PoweredUSB , 1 x LAN - RJ-45
- MTBF
- 360,000 hour(s)
- Software Included
- Epson Server Direct Print, ePOS-Print, ePOS-Display, TM Utility
- OS Required
- 5 °C
- 45 °C
- 10 - 90%
- 14.5 cm
- 19.5 cm
- 14.8 cm
- 1.6 kg
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HKZ4 048660 Condition: Customer return - item has been opened but is in excellent condition |
£49.27 |
Ref:
HKZ4 048661 Condition: Customer return - item has been opened but is in excellent condition |
£49.27 |
Ref:
HKZ4 048662 Condition: Customer return - item has been opened but is in excellent condition |
£49.27 |
Ref:
HKZ4 048663 Condition: Customer return - item has been opened but is in excellent condition |
£49.27 |
Ref:
HKZ4 048664 Condition: Customer return - item has been opened but is in excellent condition |
£49.27 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
