Offering a cleaner, more environmentally-friendly alternative to monochrome laser printers, this model is part of the market's first professional monochrome inkjet range developed for the office. Printing up to 10,000 pages in a single cartridge, this printer boasts a high yield and is low maintenance, helping to reduce the number of cartridge replacements needed.
Ink cartridges and the waste ink pad are the only consumables that need replacing in the printer – freeing up storage space previously taken up by laser toners, fusers and photoconductors.
Businesses get top-quality mono prints that are water, smudge, highlighter and fade resistant, as they dry instantly. With a large paper capacity of 330 pages - split between 250 pages in the front paper tray and 80 pages in the rear paper tray - users are able to concentrate on their work rather than refilling paper trays.
Compatible with Epson's mobile printing app, Epson iPrint, documents can be printed wirelessly from smartphones and tablet PCs within the office.
Low maintenance
Ultra-high yield ink cartridges. -
Low running costs
Up to 50% lower cost per page. -
Eco-friendly
80% lower energy consumption. -
High performance
Fast, automatic duplex printing.
- Epson WorkForce Pro WP-M4015 DN - printer - B/W - ink-jet
- Printer Type
- Workgroup printer - ink-jet - B/W
- 10.9 kg
- Inkjet Technology
- Epson On-demand Inkjet
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 26 ppm - B/W , Up to 16 ppm - B/W (ISO/IEC 24734)
- Max Resolution (B&W)
- 1200 x 600 dpi
- Automatic Duplexing
- Interface
- USB, LAN
- RAM Installed (Max)
- 64 MB
- Media Type
- Envelopes, plain paper
- Total Media Capacity
- 330 sheets
- Media Handling
- 250-sheet input tray, 80-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 20000 pages
- Networking
- Print server - Ethernet, Fast Ethernet
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6 or later, Apple MacOS X 10.5 or later, Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
- Microsoft Certification
- Compatible with Windows 7
- 46 cm x 42 cm x 28.4 cm
- Printer Type
- Workgroup printer - ink-jet - monochrome
Printer
- Inkjet Technology
- Nozzle Configuration
- 152 nozzles
- Minimum Ink Droplet Size
- 3 pl
- Ink Type
- Epson DURABrite Ultra inks
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 1200 x 600 dpi
- Media Handling
RAM
- 64 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
- Media Weight
- 64 g/m² - 256 g/m²
- 330 sheets
- Media Feeders
- 1 x automatic - 250 sheets , 1 x automatic - 80 sheets
- Max Media Capacity
- 580 sheets
Duty Cycle
- 20000 pages
- Networking
- Print server
- Data Link Protocol
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (black)
- Power Device
- Power supply - internal
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- ENERGY STAR
- Sound Emission (Operating)
- 48 dBA
- 46 cm
- 42 cm
- 28.4 cm
- 10.9 kg
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.67 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £9.82 |
