Laser-like looks, emulations and performance, combined with reliability and up to 50% lower running costs(1)
A high-performance, double-sided business inkjet all-in-one, created for demanding enterprise workgroups, with a universal print driver and a range of emulations expected by IT managers - PCL6 PCL5c and genuine Adobe® PostScript® 3™
Easy to integrate into an Enterprise environment
Network-ready for easy sharing, and including PCL6, PCL5c and genuine Adobe® PostScript® 3™ emulations, this top-of-the-range all-in-one printer with fax can easily replace a workgroup laser printer and offer much more, such as double-sided printing, copying, scanning and faxing.
Up to 50% lower running costs
Up to 50% lower cost per page than competitive lasers(1) thanks to high yield individual cartridges, providing up to 3,400 pages each(2). Ink cartridges are the only consumable that needs replacing in the printer - freeing up storage space previously taken up by laser toners, fusers and photoconductors.
Engineered for Business
With a paper capacity of up to 580 sheets spread across 3 paper trays (one is optional), you won't need to replace your paper type with another when you wish to switch formats. A high print resolution of up to 4800x1200dpi means that businesses get top-quality prints which are water, smudge, highlighter and fade resistant, as they dry instantly thanks to Epson DuraBrite Ultra ink.
Economical and Ecological
ENERGY STAR®-qualified and offering a massive 80% reduction(3) in energy consumption compared to competitive lasers, the WP-4595 DNF provides significant cost and environmental savings.
Print on the move
This printer comes with Epson Connect(4) to meet mobile printing needs, enabling users to print from smartphones and tablet PCs.
*1 Comparison made against the top 10 A4 colour laser printers and MFPs sold in France, Germany, Italy, Spain, and the UK in Q4 2010 as tracked by IDC. Cost per page is calculated from manufacturers' official list prices for toner cartridges and published yields in France, Germany, Italy, Spain, and the UK as of December 2010
*2 In accordance with ISO/IEEE 24711/24712
*3 Comparison made against the top 10 A4 Colour Laser Printers & MFPs sold in France, Germany, Italy, Spain, & UK in Q1 2011 tracked by IDC; power consumption calculated using manufacturers' published data for Print/Average Mode as of July 2011
*4 Supports the following languages: English, German, French, Italian, Spanish, Portuguese, Dutch. Requires a wireless connection to the internet. For more information, and supported devices, please visit www.epson.co.uk/connect
*5 Determined in accordance with ISO/IEC 24734 showing the average of ESAT / FSOT from the Office Category Test for default simplex / duplex. For more information visit www.epson.eu/testing
*6 Only printing is supported under Windows Server OS, bundled applications are not supported
*7 While using an ESC/P-Raster driver
Ideal for workgroups
PCL6, PCL5c, Adobe PostScript 3. -
Low running costs
Up to 50% lower cost per page. -
Top-of-the-range 4-in-1
Double-sided print, copy, scan, fax. -
Low Maintenance
Up to 3400 pages cartridge yield. -
Ecological
80% lower energy consumption.
- Epson WorkForce Pro WP-4595 DNF - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson Micro Piezo - 4-ink
- Monthly Duty Cycle (max)
- 30000 impressions
- Max Copying Resolution
- Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
- Max Printing Speed
- Up to 16 ppm (mono) / up to 11 ppm (colour)
- Max Printing Resolution
- Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 1200 dpi
- Display
- 2.5"
- Original Size
- 216 x 297 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 30 sheets
- Media Size
- Legal (216 x 356 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Standard Media Capacity
- 330 sheets
- Max Media Capacity
- 580 sheets
- Bypass Feeder Capacity
- 80 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN
- Office Machine Features
- Scan to e-mail
- Power
- AC 110/230 V (50/60Hz)
- 46 cm x 42 cm x 34.1 cm
- 13.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Copier Type
- Digital
- Fax Type
- Plain paper
- Ink-jet - colour
- 30000 impressions
- Display Diagonal Size
- 2.5"
- Interface
- USB 2.0, LAN
- Scan to e-mail
- Standard Memory
- 384 MB 384 MB
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
Printing
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 152 nozzles (black), 3 x 152 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 3 pl
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, EPSON ESC/P Raster
- Ink Type
- Epson DURABrite Ultra inks
- First Print Out Time B/W
- 7 sec
- First Print Out Time Colour
- 9 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Interpolated Resolution
- 1200 x 2400 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 60 station(s)
- Automatic redialing, colour faxing, group dialling
Document & Media Handling
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- 30 sheets
- Max Media Size
- Legal
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 256 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C4 (229 x 324 mm)
- 330 sheets
- 580 sheets
- 80 sheets
- 150 sheets
- Input tray - 250 sheets - Legal (216 x 356 mm) , ADF - 30 sheets , Input tray - 80 sheets , Output tray - 150 sheets
- Speed Details
- Printing: up to 26 ppm (A4) - B/W , Printing: up to 24 ppm (A4) - colour , Printing: up to 16 ppm (A4) - B/W (ISO/IEC 24734) , Printing: up to 11 ppm (A4) - colour (ISO/IEC 24734)
- 1 x USB 2.0 , 1 x LAN
- Network Protocols
- TCP/IP, HTTP, IPv4, IPv6, Bonjour, BOOTP
- Operating System Support
- MS Windows Server 2003, MS Windows XP Professional x64 Edition, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.4.11, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), Apple Mac OS X 10.5.x, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows XP SP1 or later
- Voltage Required
- 17 Watt
- Power Consumption Standby
- 9 Watt
- Power Consumption Sleep
- 2.4 Watt
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- ENERGY STAR Certified
- Limited warranty - 1 year
- 46 cm
- 42 cm
- 34.1 cm
- 13.8 kg
- 10 °C
- 35 °C
