Epson WorkForce Pro WF-M5190DW Mono A4 Inkjet Printer
Quicklinx: B9MKWS00 Mfr#: C11CE38401BY
Ecological
The WF-M5190DW uses up to 80 percent less power than competitive mono lasers thanks, in part, to its no heat technology. No Ozone gas is emitted and an improved quiet print mode and no fan noise during or after printing make it ideal for the work environment.
Low running costs
The WF-M5190DW's high-capacity ink cartridges of up to 10,000 pages allow you to print for longer and lower your running costs. And there are fewer parts to replace than a laser.
Save time
This efficient business printer has print speeds of up to 34ppm, (20ppm ISO print speed ). Its maximum paper capacity of 580 sheets means less time is spent refilling, and a monthly duty cycle of up to 35,000 pages4means you can print lots in confidence.
Built for business
PrecisionCore technology powers the output quality that Epson is known for, at the speeds required for office, commercial and industrial printing. Prints dry fast thanks to the DURABrite Ultra ink. Wi-Fi Direct capability lets you print from supported wireless devices without connecting to a router. Email Print for Enterprise5 allows you to securely send documents directly to the printer. Available with direct printing and pull print modes, this secure system integrates seamlessly into your existing IT infrastructure.
  • Ecological
    The WF-M5190DW uses up to 80 percent less power than competitive mono lasers thanks, in part, to its no heat technology. No ozone gas is emitted and an improved quiet print mode and no fan noise during or after printing make it ideal for the work environment.
  • Low running costs
  • Save time
    This efficient business printer has print speeds of up to 34 ppm, (20 ppm ISO print speed). Its maximum paper capacity of 580 sheets means less time is spent refilling, and a monthly duty cycle of up to 35,000 pages means you can print lots in confidence.
  • Built for business
Epson WorkForce Pro WF-M5190DW - printer - B/W - ink-jet
Printer Type
Workgroup printer - ink-jet - B/W
11.2 kg
Inkjet Technology
Epson PrecisionCore
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Print Speed
Up to 34 ppm - B/W , Up to 20 ppm - B/W (ISO/IEC 24734) , Up to 11 ppm - B/W duplex (ISO/IEC 24734) - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 2400 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n)
AirPrint Enabled
Language Simulation
PCL 5E, PCL 5C, PostScript 3, PCL 6, EPSON ESC/P Raster, PDF 1.7
Media Type
Envelopes, plain paper, thick paper
Total Media Capacity
330 sheets
Media Handling
250-sheet input tray, 80-sheet multipurpose tray
Monthly Duty Cycle (max)
35000 pages
Print server
Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5.8 or later, Apple MacOS X 10.6.x, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.8.x, Microsoft Windows Server 2012 x64 Edition
46.1 cm x 42.2 cm x 28.4 cm
Printer Type
Workgroup printer - ink-jet - monochrome
Printer
Inkjet Technology
Epson PrecisionCore
Nozzle Configuration
1600 nozzles
Minimum Ink Droplet Size
6.1 pl
Ink Type
Epson DURABrite Ultra inks
Print Speed
Wireless
AirPrint Enabled
1200 x 2400 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
7 sec
Language Simulation
Media Handling
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
Media Weight
64 g/m² - 256 g/m²
330 sheets
Media Feeders
1 x automatic - 250 sheets , 1 x automatic - 80 sheets
Max Media Capacity
580 sheets
Output Trays Capacity
150 sheets
Duty Cycle
35000 pages
Print server
Remote Management Protocol
SNMP, IPP, HTTP, SLP
Security Protocols & Features
SSL, WEP, WPA-PSK, IPsec, 802.1x, Wi-Fi Direct, WPA2-Enterprise
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x ink cartridge (black)
Power supply - internal
Frequency Required
50 - 60 Hz
25 Watt
Power Consumption Stand by
6.3 Watt
Power Consumption Sleep
2.3 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
Sound Emission (Operating)
52 dBA
46.1 cm
42.2 cm
28.4 cm
11.2 kg
