Low TCO printing
Take advantage of a low Total Cost of Ownership (TCO), and print up to 7,000 colour and 10,000 mono pages using easy-to-change, high-capacity DURABrite Pro ink cartridges.
Ecological
Uses up to 80% less power than competitive colour lasers thanks to the no heat technology. No ozone gas is emitted, and an improved quiet print mode and no fan noise during or after printing make it ideal for the workplace. And there are fewer parts to replace than a laser.
Enhance productivity
Print at up to 34 pages per minute (ppm) in both colour and mono, with ISO print speeds of 24 ppm for both . The WF-8590D3TWFC delivers automatic double-sided A4 and A3 printing for eco-friendly and business-quality results, and features one-pass duplex scanning and a 50-sheet Automatic Document Feeder. Scalable optional paper trays take its maximum capacity to 1,831 sheets.
Built for business
Epson's PrecisionCore technology powers the output quality and reliability at the speeds required for both office and industrial printing. A smartphone-like 12.7cm colour touchscreen is easy to use, while scan-to functions, including Microsoft SharePoint4, and LDAP address book compatibility make it ideal to share documents. Also securely print using a PIN code to release confidential documents, or use Email Print for Enterprise5 to securely send documents directly to the multifunction printer.
Low total cost of ownership
For cost-conscious offices this business printer saves money with its low total cost of ownership. It uses Epson's DURABrite Pro inks in easy-to-change, high-capacity cartridges of up to 7,000 colour and 10,000 mono pages. -
Ecological
The WF-8590D3TWFC uses up to 80 percent less energy than competitive colour lasers thanks to its no-heat technology. -
The lack of warm-up time helps this printer deliver fast and efficient business printing, with print speeds of up to 34ppm in both colour and mono, and 20ppm ISO print speeds in both. -
Easy to use
Easily control the printer using its smartphone-like 12.7cm touch-screen. Automatic double-sided printing, scanning, copying and faxing as standard makes any job easy and means less paper is used too. In addition, front-loading ink cartridges are easy to change. -
PrecisonCore technology
PrecisionCore technology powers the output quality and reliability that Epson is known for, at the speeds required for office, commercial and industrial printing. It's the use of PrecisionCore that aids printing onto a range of different media. Accordingly, the printer has a rear paper feed tray for A3+ and printing onto thicker card, envelopes and labels. -
Built for business
Its flexible connectivity allows this printer to seamlessly integrate into office networks. Wi-Fi and Wi-Fi Direct, PDL printer emulations, and Gigabit Ethernet all help to boost office productivity. PC-less scan-to functions, including Microsoft SharePoint using Document Capture Pro. -
Print from anywhere
Stay connected and productive. Email Print for Enterprise.
- Epson WorkForce Pro WF-8590 D3TWFC - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson PrecisionCore - 4-ink
- Monthly Duty Cycle (max)
- 65000 pages
- Max Copying Speed
- Up to 22 ppm (mono) / up to 21 ppm (colour)
- Max Copying Resolution
- Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
- Max Printing Speed
- Up to 24 ppm (mono) / up to 24 ppm (colour)
- Max Printing Resolution
- Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 2400 dpi
- Original Size
- A3 (297 x 420 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- A3 Plus (329 x 483 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Standard Media Capacity
- 1830 sheets
- Max Media Capacity
- 1831 sheets
- Bypass Feeder Capacity
- 80 sheets
- Output Trays Capacity
- 250 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to Cloud
- Power
- AC 230 V
- 59 cm x 57 cm x 58.9 cm
- 46.4 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Ink-jet - colour
- 65000 pages
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Inkjet Technology
- Nozzle Configuration
- 400 nozzles (black), 3 x 400 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 3.7 pl
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PCL 5c, EPSON ESC/P Raster, PDF 1.7
- Ink Type
- Epson DURABrite Pro inks
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 550 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 200 station(s)
- Automatic redialing, colour faxing, Duplex Fax
Document & Media Handling
- Max Original Size
- A3 (297 x 420 mm)
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A3
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 256 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 200 x 250 mm, A3 Plus (329 x 483 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International C6 (114 x 162 mm), International C4 (229 x 324 mm)
- 1830 sheets
- 1831 sheets
- 80 sheets
- 250 sheets
- Input tray - 250 sheets , ADF - 50 sheets , Input tray - 80 sheets , Output tray - 250 sheets , 3 x input tray - 500 sheets
- Speed Details
- Printing: up to 34 ppm - B/W , Printing: up to 34 ppm - colour , Printing: up to 24 ppm - B/W (ISO/IEC 24734) , Printing: up to 24 ppm - colour (ISO/IEC 24734) , Printing: up to 16 ppm (A4) - B/W duplex (ISO/IEC 24734) , Printing: up to 16 ppm (A4) - colour duplex (ISO/IEC 24734) , Copying: up to 22 ipm - B/W (ISO/IEC 24735) , Copying: up to 21 ipm - colour (ISO/IEC 24735) , Scanning: up to 23 ipm (A4) - B/W , Scanning: up to 23 ipm (A4) - colour , Scanning: 5 sec (A4) - B/W , Scanning: 7 sec (A4) - colour
- 1 x USB 2.0 , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- LDAP, SSL, WEP, WPA-PSK, WPA2, IPsec, 802.1x, Wi-Fi Direct
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, Apple Mac OS X 10.5.8, MS Windows Vista, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.7.x, Apple Mac OS X 10.8.x, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.6 or later
- Software Included
- Epson Connect
- Voltage Required
- AC 230 V
- 39 Watt
- Power Consumption Standby
- 17 Watt
- Power Consumption Sleep
- 2.4 Watt
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- ENERGY STAR Certified
- 59 cm
- 57 cm
- 58.9 cm
- 46.4 kg
- Sound Emission
- 52 dBA (operating)
