A4 sheet-fed scanner
Performance and productivity This compact scanner has scanning speeds of up to 26ppm / 52ipm, even at 300dpi in colour. This, combined with hardware JPEG compression, makes large scan jobs faster to process.
Seamless integration into document management and cloud systems Epson Document Capture and Document Capture Pro make it easy to integrate this scanner into your document management system, speeding up workflow and enabling you to capture, convert and distribute scanned information into your document filing systems. In addition, the Pro version for Windows offers barcode recognition and Zonal OCR to help automate document processes, such as file naming and folder creation.
Scan software included or download our new free app Epson Scan1 offers a wide selection of advanced document imaging features, including text enhancement and automatic de-skew, which help improve efficiency and increase workload output. This model also scans to .docx, .xlsx and .pptx. Scan to your Android or Apple mobile device by downloading the new Epson DocumentScan app from Google Play or the Apple App Store.
Flexible connectivity Wi-Fi, Wi-Fi DirectTM and USB interfaces allow you to conveniently connect to this scanner.
Key Features -High-speed scanning Scanning speeds of up to 26ppm / 52ipm, even at 300dpi in colour -Flexible connectivity Wi-Fi and Wi-Fi DirectTM connectivity, plus a USB interface -Fast processing Hardware JPEG compression -Seamless integration into document management and cloud systems Epson Document Capture and Document Capture Pro -Scan software/app for PC, Mac, mobile Advanced document imaging features help improve efficiency
- To use this app, connect from a mobile device to the DS-560 via Wi-Fi or Wi-Fi DirectTM. Load documents onto the DS-560 and start scanning via the app on your mobile device. Simply choose your settings, press 'Scan', view the scanned image on the screen and export it to cloud services or other document management systems.
The WorkForce DS-560 is an A4 sheet-fed scanner, ideal for small to medium businesses and governments, banks and healthcare establishments.
- Epson WorkForce DS-560 - document scanner - desktop - USB 2.0, Wi-Fi(n)
- Document scanner - desktop
- Interface Type
- USB 2.0, Wi-Fi(n)
- Light Source
- LED
- Additional Functions
- Email, scan to server
- Max Supported Document Size
- A4 (210 x 297 mm)
- Input Type
- Grayscale / Color Depth
- 16-bit (64K grey levels) / 48-bit colour
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 26 ppm (mono) / 26 ppm (colour)
- Max Document Size
- 216 mm x 914 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, business card, plastic card
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Duty Cycle
- 3000 scans per day
- System Requirements
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5.8 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8
- Microsoft Certification
- Compatible with Windows 7
- 29.7 cm x 15.2 cm x 15.4 cm
- 2.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- USB 2.0, Wi-Fi(n)
- A4 (210 x 297 mm)
Scanner
- Input Type
- Grayscale Depth
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Scan Mode
- Single-pass
- Bulb / Light Source Type
- LED
- Max Document Scan Speed B/W
- 26 ppm
- Max Document Scan Speed Colour
- 26 ppm
- Duty Cycle
- Scanner Speed Details
- 26 ppm - black & white - A4 - 300 dpi , 52 ipm - duplex - black & white - A4 - 300 dpi , 26 ppm - colour - A4 - 300 dpi , 52 ipm - duplex - colour - A4 - 300 dpi
- Scanner Features
- EPSON ReadyScan LED Technology, Automatic Separation, Barcode Detection, Auto Document Rotation, Punch Hole Removal, A3 stitching
- TWAIN, WIA
Media Handling
- Max Document Size
- 216 mm x 914 mm
- Automatic
- 50 sheets
- Interfaces Details
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Software Included
- ABBYY FineReader 9.0 Sprint, EPSON Document Capture Pro, ABBYY FineReader 8.0 Sprint for MAC
- OS Required
- 29.7 cm
- 15.2 cm
- 15.4 cm
- 2.5 kg
- Limited warranty - 1 year - on-site
