Scanning up to 40 pages per minute, this efficient and reliable device meets the needs of medium and large businesses seeking enhanced document workflow. This scanner provides fast and trouble-free scanning due to a 200 A3-page ADF, one-pass duplex scanning, and double feed detection. Additionally, the 'scan to' functions offered by Document Capture Pro enable even greater productivity.
Document Capture Pro makes it easy to integrate this scanner into your document management system, speeding up workflow and enabling users to capture, convert and distribute scanned information in virtually any document repository or document management systems.
This scanner and its features can be shared between multiple users using the optional Network Interface Panel. Combined with Document Capture Pro solutions, the Network Interface Panel allows users to benefit from Push Scan features and customise 'scan to' job functions, such as 'scan to email' or 'scan to Microsoft SharePoint ', among others. These features enable complicated tasks to be carried out effortlessly, increasing users' acceptance and eliminating training requirements.
Epson ReadyScan LED technology eradicates warm-up time, guarantees an absence of mercury, and lowers power consumption. These elements, combined with ENERGY STAR qualification, creates an environmentally friendly device.
Efficient scanning
With automatic duplexing and a feeder capacity of 200 sheets, the Epson WorkForce DS-60000 streamlines document management by efficiently handling large volumes of paper, saving time and improving workflow. -
High-quality imaging
Achieve high image clarity with a max optical resolution of 600 DPI, ensuring that every detail is captured with precision. Whether scanning in color or black and white, documents are rendered with high quality. -
Versatile compatibility
Designed to work seamlessly with both Mac and PC, the Epson WorkForce DS-60000 offers flexible connectivity options through its USB 2.0 interface, making it a versatile choice for any office environment. -
Eco-conscious operation
ENERGY STAR certification signifies that the Epson WorkForce DS-60000 not only meets high standards of efficiency but also operates with a lower environmental impact, consuming only 79 W during operation.
- Epson WorkForce DS-60000 - document scanner - USB 2.0
- Document scanner
- Interface Type
- USB 2.0
- Max Supported Document Size
- A3 (297 x 420 mm)
- Input Type
- Grayscale / Color Depth
- 8-bit (256 colours) / 16-bit (64k colours)
- Grayscale / Color Depth (External)
- 24-bit (16.7 million colours) / 48-bit colour
- Optical Resolution
- 600 dpi x 600 dpi
- Interpolated Resolution
- 9600 dpi x 9600 dpi
- Max Document Scan Speed
- 40 ppm (mono) / 40 ppm (colour)
- Max Document Size
- 297 mm x 2540 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 200 sheets
- Duty Cycle
- 5000 scans per day
- Power
- AC 120/230 V
- System Requirements
- Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server Terminal Server, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2003 R2, Citrix Presentation Server 4.5, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Citrix XenApp 5, Citrix XenApp 6
- 64 cm x 52.2 cm x 28.9 cm
- 26.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Document scanner
- Interface Type
- USB 2.0
- A3 (297 x 420 mm)
Scanner
- Input Type
- Grayscale Depth
- Grayscale Depth (External)
- Colour Depth
- 16-bit (64k colours)
- Colour Depth (External)
- 48-bit colour
- 600 dpi x 600 dpi
- Max Document Scan Speed B/W
- 40 ppm
- Max Document Scan Speed Colour
- 40 ppm
- Duty Cycle
- Scanner Speed Details
- 80 ipm - colour , 80 ipm - black & white
- Scanner Features
- EPSON ReadyScan LED Technology, Remove Punch Hole, RGB Color Dropout
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 297 mm x 2540 mm
- Plain paper
- Automatic
- 200 sheets
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Voltage Required
- AC 120/230 V
- Power Consumption Operational (Standby)
- 79 Watt (1.5 Watt)
- Software Included
- EPSON Scan, EPSON Event Manager, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint Plus for MAC, EPSON Document Capture Pro
- OS Required
- 64 cm
- 52.2 cm
- 28.9 cm
- 26.9 kg
- Limited warranty - 1 year - on-site
- 5 °C
- 35 °C
- 10 - 80%
Epson CoverPlus 3 Years onsite Warranty | In Stock | £568.60 |
Epson 3 Years CoverPlus Onsite For Workforce DS-50000 | In Stock | £451.36 |
