Epson TM-U220-PB Receipt Printer
Quicklinx: 75TGWS00 Mfr#: C31C517057
1ST IMPACT PACKAGED PRINTER * PS, NES; Parallel; Epson Cool White (ECW); Power Supply.
  • Easy-to-use impact printer
    If you need a hard worker that's easy to use and versatile, this is the ideal impact receipt printer.
Epson TM U220PB - receipt printer - two-colour (monochrome) - dot-matrix
Printer Type
Receipt printer - dot-matrix - 9 pin - two-colour (monochrome)
2.5 kg
Max Media Size
Roll (7.6cm)
Max Media Size (Custom)
76 mm
Print Speed
Up to 6 lines/sec , Up to 4.7 lines/sec
Max Resolution (B&W)
16 cpi
Cutter
Parallel
Total Media Capacity
1 roll
Enclosure Colour
Dark grey
1-year warranty
16 cm x 24.8 cm x 13.9 cm
Printer Type
Enclosure Colour
Dark grey
Printer
Print Speed
Up to 6 lines/sec - 16 cpi , Up to 4.7 lines/sec - 16 cpi
Built-in Devices
Cutter
Wired
Parallel
16 cpi
Character Sizes (mm)
1.2 x 3.1 mm, 1.6 x 3.1 mm
Columns
33, 35, 40, 42
Auto Cutter
Media Handling
Max Media Size
Roll (7.6cm)
76 mm
Media Sizes
Roll (7 cm), Roll (7.6cm), Roll (5.8 cm)
Media Thickness Range
0.06 mm - 0.085 mm
Roll Maximum Outer Diameter
83 mm
1 roll
Media Feeders
1 x manual - 1 roll - Roll (7.6cm)
1 x parallel
Mounting Kit
Optional
MTBF
180,000 hour(s)
FCC Class A certified, CSA, UL, TUV, EN 60950, EN55022, VCCI Class A ITE, EN55024
Power adapter - external
Limited warranty - 1 year - carry-in
Sound Emission (Operating)
64 dBA
16 cm
24.8 cm
13.9 cm
2.5 kg
Ink (1)
75TG Epson ERC38BR Cartridge for TM-300/U300/U210D/U220/U230 Black/Red In Stock £3.04
Other bundles (1)
75TG Epson Power Supply 100-230V In Stock £42.01
