Label and barcode printing
With fast, thermal printing of up to 150mm/sec, the TM-L90 is a valuable asset to your business. With this model, you'll be able to print out and get on with more important work, rather than waiting around for labels or barcodes.
More connectivity
This printer benefits from high speed serial, Ethernet and parallel connectivity plus a built-in USB interface, which means it can be operated as a network device.
Easy to use
The small footprint and wall bracket mean that you can place it almost anywhere, in any position, for convenient and versatile printing. Practical design features, such as drop-in paper load, selectable auto-cutter and jamproof paper feeding, ensure smooth operation. The easy-to-use operator cover and lifespan of up to 20 million lines enable long-lasting, trouble-free maintenance.
High quality labels
Its greyscale capabilities allow highly customised layouts, and logos and promotional messages can be added with ease.
Larger receipt rolls, wider paper
Altogether, the TM-L90 label printer is one of the most efficient label printers available: it accepts large paper rolls (up to 90mm in diameter) and you can select paper widths between 38 and 80mm to produce labels in different sizes.
With fast, thermal printing of up to 150mm/sec, the TM-L90 is a valuable asset to your business. With this model, you'll be able to print out and get on with more important work, rather than waiting around for labels or barcodes. -
More connectivity
This printer benefits from high speed serial, Ethernet and parallel connectivity plus a built-in USB interface, which means it can be operated as a network device. -
Easy to use
The small footprint and wall bracket mean that you can place it almost anywhere, in any position, for convenient and versatile printing. Practical design features, such as drop-in paper load, selectable auto-cutter and jamproof paper feeding, ensure smooth operation. The easy-to-use operator cover and lifespan of up to 20 million lines enable long-lasting, trouble-free maintenance. -
High quality labels
Its greyscale capabilities allow highly customised layouts, and logos and promotional messages can be added with ease. -
- Epson TM L90 - receipt printer - B/W - thermal line
- Printer Type
- Receipt printer - thermal line - B/W
- 1.9 kg
- Max Media Size
- Roll (8 cm)
- Max Media Size (Custom)
- 80 mm
- Print Speed
- Up to 150 mm/sec - max speed
- Max Resolution (B&W)
- 203 dpi
- Cutter
- Interface
- USB 2.0, serial
- RAM Installed (Max)
- 4 KB
- Media Type
- Labels, receipt paper
- Microsoft Certification
- Compatible with Windows 7
- Enclosure Colour
- Dark grey
- 2-year warranty
- 14 cm x 14.8 cm x 20.3 cm
- Printer Type
- Receipt printer - thermal line - monochrome
- Enclosure Colour
- Dark grey
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB 2.0, serial
- 203 dpi
- Character Sizes (mm)
- 1.5 x 3 mm, 1.1 x 2.1 mm
- Columns
- 38, 70
- Cutter
- Fonts Included
- 1 x barcode
RAM
- 4 KB
Media Handling
- Media Type
- Max Media Size
- Roll (8 cm)
- 80 mm
- Media Sizes
- Roll (8 cm)
- Roll Maximum Outer Diameter
- 90 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (8 cm)
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x serial
- Included Accessories
- Paper roll spacer, power switch cover
- Media Included
- 1 thermal roll paper
- MTBF
- 360,000 hour(s)
- FCC Class A certified, CSA, UL, TUV, AS/NZS 3548, VCCI Class A
- Power Device
- Power adapter - external
- Limited warranty - 2 years
- 5 °C
- 45 °C
- 10 - 90%
- Sound Emission (Operating)
- 53 dBA
- 14 cm
- 14.8 cm
- 20.3 cm
- 1.9 kg
Epson Power Supply 100-230V | In Stock | £41.36 |
