Epson UltraChrome K3 Ink with Vivid Magenta uses 9 pigment inks to give your prints a very wide colour gamut and exceptional light fastness. Three levels of black deliver a perfectly balanced grey scale and smooth tonal gradations, and auto-switching between optimised photo and matte black gives you the best results on your chosen media.
Produce borderless photos from 4" up to 17" wide and any length you define, up to 37.4". Print on a wide variety of photo, fine art and proofing media, and add flexibility with three cut-sheet paper paths that handle media and posterboard up to 1.5 mm in thickness. This is perfect for POS applications and with the compact footprint retailers can easily fit this printer in store or office.
The Epson Stylus Pro 3880 is also ideal for remote proofing. Prints are so consistent that you can sign-off proofs quickly, certain that what you see is what you will get in the final print run.
With the excellent colour stability and light fastness of Epson UltraChrome K3 Ink with Vivid Magenta, you can create long-lasting prints to sell or exhibit. Exceptional accuracy ensures that each reprint will match the first, even if printed months apart.
- Epson Stylus Pro 3880 - large-format printer - colour - ink-jet
- Printer Type
- 17" large-format printer - ink-jet - colour
- 19.8 kg
- Inkjet Technology
- Epson Micro Piezo with Active Meniscus Control (AMC)
- Ink Palette Supported (Colours)
- 8-ink - cyan, vivid magenta, yellow, light black, light cyan, vivid light magenta, light light black, photo black or matte black
- Max Media Size
- A2 (420 x 594 mm), ANSI C (432 x 559 mm)
- Max Resolution (B&W)
- 2880 x 1440 dpi
- Max Resolution (Colour)
- 2880 x 1440 dpi
- Image Enhancement Technology
- EPSON Variable-sized Droplet Technology
- Interface
- USB, LAN
- Language Simulation
- EPSON ESC/P 2
- Media Type
- Plain paper, fine art paper, semimatte coated fibre paper, glossy paper, matte paper
- Total Media Capacity
- 120 sheets
- Media Handling
- 120-sheet input tray, 1-sheet manual tray
- Networking
- Print server - Ethernet, Fast Ethernet - internal
- Printer Features
- Borderless printing
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Apple MacOS X 10.3.9, Apple MacOS X 10.4.x, Microsoft Windows Vista, Apple MacOS X 10.5.x
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty (Poland - 2 years on-site)
- 68.4 cm x 37.6 cm x 25.7 cm
- Printer Type
Printer
- Inkjet Technology
- Nozzle Configuration
- 8 x 180 nozzles
- Minimum Ink Droplet Size
- 3.5 pl
- Ink Cartridge Configuration
- 8 individual ink tanks
- Ink Type
- Epson UltraChrome K3 with Vivid Magenta
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 2880 x 1440 dpi
- 2880 x 1440 dpi
- EPSON ESC/P 2
- Colour Management Features
- ICC Color Profiles
- Printer Features
- Media Handling
Media Handling
- Media Type
- Max Media Size
- Borderless Photo Sizes
- Super A3/B (330 x 483 mm), 100 x 150 mm, ANSI C (432 x 559 mm), 279 x 356 mm, 127 x 177.8 mm, 203.2 x 254 mm
- Media Thickness Range
- Up to 1.5 mm
- 120 sheets
- Media Feeders
- 1 x manual - 1 sheet , 1 x automatic - 120 sheets - A2 (420 x 594 mm)
- Networking
- Print server - internal
- Data Link Protocol
- Connections
- 1 x USB 2.0 - 4 pin USB Type B ¦ 1 x LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (cyan) - 80 ml , 1 x ink cartridge (vivid magenta) - 80 ml , 1 x ink cartridge (yellow) - 80 ml , 1 x ink cartridge (light cyan) - 80 ml , 1 x ink cartridge (vivid light magenta) - 80 ml , 1 x ink cartridge (light black) - 80 ml , 1 x ink cartridge (light light black) - 80 ml , 1 x ink cartridge (photo black) - 80 ml , 1 x ink cartridge (matte black) - 80 ml
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 25 Watt
- Power Consumption Stand by / Sleep
- 5 Watt
- Software Included
- EPSON CopyFactory, EPSON ColorBase 2.0, EPSON LFP Remote panel software
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year
- Regional Warranty Exceptions
- Poland - 2 years on-site
- 10 °C
- 35 °C
- 20 - 80%
- Sound Emission (Operating)
- 39 dBA
- 68.4 cm
- 37.6 cm
- 25.7 cm
- 19.8 kg
Ink (14)
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £15.10 |
Epson T5807 Black Ink Cartridge | In Stock | £40.14 |
Epson T5809 Black Ink Cartridge | In Stock | £44.08 |
Epson Stylus Pro 3800 Cyan (80ml) | In Stock | £45.29 |
Epson STY PRO 380O MAINTENANCE TANK | In Stock | £15.83 |
Epson Premium Glossy Photo Paper - glossy photo paper - 15 sheet(s) | In Stock | £12.67 |
Epson EPSON T580B00 INK CARTR.L.MAG. | In Stock | £39.43 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.61 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.61 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £15.01 |
Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) | In Stock | £15.01 |
Epson A3+ Glossy Photo Paper | In Stock | £21.97 |
Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) | In Stock | £21.97 |
Epson A3 Matte Paper Heavyweight 50 sheets | In Stock | £29.97 |
Other bundles (1)
Epson A2 Premium Glossy Photo Paper - 25 Sheets | In Stock | £37.72 |
