Epson LQ 680Pro Mono Dot-Matrix Printer
Quicklinx: 65NVWS00 Mfr#: C11C376125A1
The new 24 dot-matrix LQ-680 and LQ-680 Pro printers from Epson. Improved technology, improved features at a low price. The ergonomic flat bed printers are ideal for endless forms and for normal and particularly heavy pr small single sheets, forms and labels. The LQ-680 Pro also offers an automatic paper direction change and a manual and automatic paper thickness setting.
  • Ultra-reliable flatbed printing
    The LQ-680Pro offers a performance advantage that busy offices are sure to appreciate: speed. It is networkable and can be equipped with a Type B Level 2 interface card for wide-ranging connectivity.
  • Best-in-class speed
    The LQ-680Pro offers a class-leading throughput and an amazing top speed of 413 cps. What's more, Epson's 24-pin Eco-Drive print head mechanism achieves this high level of productivity without running up your electric bill. And when a print job is finished, an auto power-saving function puts the printer in standby mode for even greater savings.
  • Unrivaled ease-of-use built into every feature
    A compact flat-top housing makes the printer ideal for countertop and desktop use. The front sheet guide has also been redesigned - it now features a lower profile, a full-flat bottom and an L-shaped edge guide for smooth, easy front loading. In addition, improved front-in, front-out paper handling ensures that front-loaded cut-sheet paper and single-sheet, multi-part forms emerge right-side-up for instant legibility.
  • Reliability and versatility
    You can now get crisp, clear output on multi-part forms up to six layers thick. Versatility is also excellent, with three-way paper handling that allows paper to be loaded from the front, rear or top.
  • On-screen status monitoring
    The LQ-680Pro is networkable and can be equipped with a Type-B Level 2 interface card for wide-ranging connectivity. In addition to the Epson status monitor 3 on-screen display, the LQ-680Pro features an auto platen gap adjuster and an auto paper changer. The auto platen gap adjuster sets the platen gap to suit the type of paper being used and this prevents paper misalignment and jamming that can cause problems during remote operation. In addition, the auto paper changer lets you switch between cut-sheet and continuous-feed forms or paper without leaving your desk.
Epson LQ 680Pro - printer - B/W - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 24 pin - B/W
9.4 kg
United Kingdom
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Max Media Size (Custom)
304.8 mm x 558.8 mm
Print Speed
Up to 413 char/sec - max speed , Up to 310 char/sec - draft , Up to 372 char/sec - draft , Up to 465 char/sec - draft , Up to 264 char/sec - draft , Up to 310 char/sec - draft , Up to 103 char/sec - letter , Up to 124 char/sec - letter , Up to 155 char/sec - letter , Up to 175 char/sec - letter , Up to 206 char/sec - letter
Max Resolution (B&W)
360 x 180 dpi
Parallel
RAM Installed (Max)
64 KB integrated
Language Simulation
EPSON ESC/P 2, IBM 2390 Plus
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
Media Type
Envelopes, labels, plain paper, continuous forms
Microsoft Windows NT 4.0, Microsoft Windows 95/98, Microsoft Windows 3.1, Microsoft Windows 2000, Microsoft Windows NT 3.5 or later, Microsoft Windows Millennium Edition
1-year warranty
49.7 cm x 38.7 cm x 23 cm
Printer Type
Workgroup printer - dot-matrix - 24 pin - monochrome
United Kingdom
Printer
Print Speed
Up to 413 char/sec - max speed - 10 cpi , Up to 310 char/sec - draft - 10 cpi , Up to 372 char/sec - draft - 12 cpi , Up to 465 char/sec - draft - 15 cpi , Up to 264 char/sec - draft - 17 cpi , Up to 310 char/sec - draft - 20 cpi , Up to 103 char/sec - letter - 10 cpi , Up to 124 char/sec - letter - 12 cpi , Up to 155 char/sec - letter - 15 cpi , Up to 175 char/sec - letter - 17 cpi , Up to 206 char/sec - letter - 20 cpi
Wired
Parallel
360 x 180 dpi
Language Simulation
Fonts Included
10 x bitmapped , 4 x scalable , 8 x barcode
Barcodes
RAM
RAM Installed (Max)
64 KB
Technology / Form Factor
Integrated
Media Handling
Media Type
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
304.8 mm x 558.8 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm)
Max Sheets in Multi-Part Form
6
1 x parallel - 36 PIN Centronics
Consumables Included
1 x ribbon (black) - up to 2 million characters
MTBF
10,000 hour(s)
EN 60950, EN 61000-3-2, EN 61000-3-3, EN55024, EN50082-1, EN55022 Class B, AS/NZS 3548 Class B
Power supply - internal
42 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
Limited warranty - parts and labour - 1 year - carry-in
5 °C
35 °C
10 - 80%
Sound Emission (Operating)
55 dBA
49.7 cm
38.7 cm
23 cm
9.4 kg
65NV Epson Black Ribbon Cartridge for LQ-670/680/pro/860/1060/25xx In Stock £7.12
