LQ-630 is a small and reliable printer especially for counter application. With its small design with 80 columns, LQ-630 fits perfectly in environments where space is rather limited. The ejection of both, continuous paper and cut sheets at front side enables easy handling of the print outs only at the front side of the printer. Due to the printer's flatbed technology, LQ-630 can print even smallest cut sheet forms and stickers down to 9 cm x 7 cm. LQ-630 can ideally be used with retail stores, banks, post offices, doctors' surgeries, ticket shops, cinemas, pizza services. Moreover the printer is perfect for label and protocol printing with trade industrial firms.
Compact, robust design for counter top use
The Epson LQ-630 24 pin dot matrix printer has a notably small footprint - perfect for restricted space environments in businesses such as retailers, surgeries, ticket offices and trade counters. -
Low cost, high quality flatbed dot matrix printer
Fast and ultra reliable, the Epson LQ-630 prints at 360 cps and is extremely economical to run. -
Ergonomic flatbed with front paper feed
The straight, flat front feed paper path is perfect for a range of applications including small cut sheet, labels and up to 5 part stationery.
- Epson LQ 630 - printer - B/W - dot-matrix
- Printer Type
- Workgroup printer - dot-matrix - 24 pin - B/W
- 3.5 kg
- Max Media Size
- JIS B4 (257 x 364 mm), continuous paper 101.6 mm - 254 mm (width)
- Print Speed
- Up to 300 char/sec - fast draft , Up to 360 char/sec - fast draft , Up to 225 char/sec - draft , Up to 79 char/sec - best
- Max Resolution (B&W)
- 360 x 180 dpi
- Interface
- Parallel, USB 2.0
- RAM Installed (Max)
- 32 KB
- Language Simulation
- EPSON ESC/P 2, IBM PPDS
- Media Type
- Labels, plain paper, continuous forms
- System Requirements
- Microsoft Windows 98, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows 7, Windows 8
- 1-year warranty
- 38.6 cm x 30.6 cm x 18.5 cm
- Printer Type
- Workgroup printer - dot-matrix - 24 pin - monochrome
Printer
- Print Speed
- Up to 300 char/sec - fast draft - 10 cpi , Up to 360 char/sec - fast draft - 12 cpi , Up to 225 char/sec - draft - 10 cpi , Up to 79 char/sec - best - 10 cpi
- Connectivity Technology
- Wired
- Interface
- Parallel, USB 2.0
- 360 x 180 dpi
RAM
- 32 KB
Media Handling
- Media Type
- Max Media Size
- Media Sizes
- Connections
- 1 x parallel - 36 PIN Centronics , 1 x USB 2.0 - 4 pin USB Type B
- MTBF
- 10,000 hour(s)
- 20 Watt
- Power Consumption Stand by
- 4.8 Watt
- Software Included
- Drivers & Utilities, EPSON Status Monitor
- OS Required
- Limited warranty - 1 year - carry-in
- 5 °C
- 35 °C
- 10 - 80%
- Sound Emission (Operating)
- 57 dB
- 38.6 cm
- 30.6 cm
- 18.5 cm
- 3.5 kg
