Epson FX-2190 Dot Matrix Printer
Quicklinx: 8YZMWS00 Mfr#: C11C526023
This wide carriage printer combines high speed printing with outstanding reliability.
A mean volume between failure of 52 million lines makes this printer suitable for medium and large print volumes. The paper can be fed from the front, top, rear or bottom and an optional additional push/pull tractor unit can store a second continuous form, which is ideal for commercial and industrial environments.
Also available as network version FX-2190N.
Epson FX 2190 - printer - B/W - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 9 pin - B/W
9.4 kg
United Kingdom
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Print Speed
Up to 680 char/sec - max speed , Up to 566 char/sec - max speed , Up to 627 char/sec - fast draft , Up to 559 char/sec - fast draft , Up to 503 char/sec - draft , Up to 419 char/sec - draft , Up to 125.9 char/sec - letter , Up to 104.6 char/sec - letter
Parallel, USB
RAM Installed (Max)
128 KB
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
Microsoft Windows 95/98, Microsoft Windows 2000 / NT4.0, Microsoft Windows Millennium Edition, Microsoft Windows XP
Microsoft Certification
Works with Windows Vista
1-year warranty
58.9 cm x 35 cm x 16.8 cm
Printer Type
Workgroup printer - dot-matrix - 9 pin - monochrome
United Kingdom
Printer
Print Speed
Up to 680 char/sec - max speed - 12 cpi , Up to 566 char/sec - max speed - 10 cpi , Up to 627 char/sec - fast draft - 12 cpi , Up to 559 char/sec - fast draft - 10 cpi , Up to 503 char/sec - draft - 12 cpi , Up to 419 char/sec - draft - 10 cpi , Up to 125.9 char/sec - letter - 12 cpi , Up to 104.6 char/sec - letter - 10 cpi
Wired
Parallel, USB
Fonts Included
3 x bitmapped , 8 x barcode
Barcodes
RAM
RAM Installed (Max)
128 KB
Media Handling
Media Size Class
A3
Max Media Size
A3 (297 x 420 mm)
Media Sizes
A3 (297 x 420 mm)
Max Sheets in Multi-Part Form
6
1 x USB , 1 x parallel
Consumables Included
1 x ribbon (black) - up to 12 million characters
MTBF
20,000 hour(s)
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Software Included
EPSON Status Monitor 3
Limited warranty - 1 year
Sound Emission (Operating)
55 dBA
58.9 cm
35 cm
16.8 cm
9.4 kg
