Epson Expression Premium XP-830 - Multifunction Colour Printer
Quicklinx: D7BCWS00 Mfr#: C11CE78401
Best of both worlds
Create outstanding glossy photos and crisp, clear text documents with the new five-colour Claria Premium dye and pigment ink-set. Photographs will be crystal clear with vibrant colours and deep, rich blacks thanks to the addition of a Photo Black ink cartridge.
Mobile printing
Whether using a smartphone or tablet, the iPrint app can be downloaded to a range of devices for truly wireless printing and scanning. The possibilities don't end there, with Epson Email Print , it is possible to print from anywhere in the world by simply emailing documents and photos directly to the printer. For creative-minded people the Creative Print app can access Facebook photos, create custom greeting cards and stationery, and even turn photos into colouring book templates. For added versatility, Wi-Fi Direct allows easy printing from compatible wireless devices without the need for a network connection.
Easy to use
A 10.9cm interactive LCD touch-screen makes navigation and printing directly from memory card quick and simple. For even easier operation, a motorised control panel and output tray mean hassle-free printing.
Advanced control
Easily switch between photo and A4-sized prints with two front-loading paper trays. Print onto thicker media using the rear speciality media feed and enjoy fast and easy double-sided copying, scanning and faxing with the ADF. You can also directly print onto suitable CDs/DVDs.
  • Versatile Wi-Fi 4-in-1
    Advanced 4-in-1 printer with duplex that produces outstanding glossy photos and documents and comes with a range of easy-to-use features.
Epson Expression Premium XP-830 - multifunction printer - colour
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 5-ink
Max Printing Speed
Up to 14 ppm (mono) / up to 11 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Scanning
4800 x 4800 dpi
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
120 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail, scan to Cloud
AC 230 V (50/60Hz)
39 cm x 33.9 cm x 19.1 cm
8.2 kg
Microsoft Certification
Compatible with Windows 7
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Features
Touch screen
AirPrint Enabled
Supported Flash Memory
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Copying
Automatic Duplexing
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
180 nozzles (per cartridge)
Max Printing Speed
Ink Cartridge Configuration
5 cartridges (1 each: cyan, magenta, yellow, black, photo balck)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black, photo black
5-ink
Minimum Ink Droplet Size
1.5 pl
Ink Type
Epson Claria Premium Ink
Automatic Duplexing
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
4800 x 4800 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Total Memory Capacity
Up to 180 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
60 station(s)
Automatic redialing
Document & Media Handling
Max Original Size
Original Type
Sheets
30 sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
90 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
120 sheets
Input tray - 100 sheets - Legal (216 x 356 mm) , ADF - 30 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 95 g/m² , Photo tray - 20 sheets
Speed Details
Printing: up to 32 ppm - B/W , Printing: up to 32 ppm - colour , Printing: up to 14 ppm - B/W (ISO/IEC 24734) , Printing: up to 11 ppm - colour (ISO/IEC 24734) , Printing: 12 sec (10 x 15 cm (4"x6")) - photo
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK, TKIP, AES, Wi-Fi Direct
Operating System Support
MS Windows XP, MS Windows 7, MS Windows Vista, MS Windows XP 64-bit Edition, Apple Mac OS X 10.6.8 or later, Windows 8
Software Included
Drivers & Utilities, EPSON Print CD, Epson Easy Photo Print, Epson Fax Utility
AC 230 V (50/60Hz)
20 Watt
Power Consumption Sleep
1.6 Watt
Direct Printing Specifications
PictBridge
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (photo black)
CISPR 22 Class B, FCC Part 15 B, UL 60950-1, CAN/CSA-C22.2 No. 60950-1
39 cm
33.9 cm
19.1 cm
8.2 kg
