Best of both worlds
Create outstanding glossy photos and crisp, clear text documents with the new five-colour Claria Premium dye and pigment ink-set. Photographs will be crystal clear with vibrant colours and deep, rich blacks thanks to the addition of a Photo Black ink cartridge. The use of individual ink cartridges means only the colour used need to be replaced to help save on ink costs.
Mobile printing
Whether using a smartphone or tablet, the iPrint app can be downloaded to a range of devices for truly wireless printing and scanning. The possibilities don't end there, with Epson Email Print , it is possible to print from anywhere in the world by simply emailing documents and photos directly to the printer. For creative-minded people the Creative Print app can access Facebook photos, create custom greeting cards and stationery, and even turn photos into colouring book templates. For added versatility, Wi-Fi Direct allows easy printing from compatible wireless devices without the need for a network connection.
Easy to use features
For maximum control, the XP-630 comes with a tilting control panel and 6.8cm LCD screen with touchpad for easy navigation. Dual paper trays, one for A4 and one for photo paper, and fast, double-sided printing helps save time. Users can also simply slot in a memory card and follow the helpful menu prompts to print photos without a PC.
Effortless connectivity
With options like AirPrint, Google Cloud Print, and Wi-Fi Direct, the Epson Expression Premium XP-630 ensures seamless connection across all your devices, making it easier than ever to print from anywhere. -
Versatile media handling
From envelopes to photo paper, the XP-630 is designed to support a wide range of media types and sizes, including A4, Legal, and more, catering to all your printing needs. -
High-quality printing
Achieve high-quality print quality with a maximum resolution of 5760 x 1440 DPI for both black and color prints, and enjoy the richness of photos printed with Epson Claria Premium Ink. -
Convenient scanning and copying
With a high optical resolution of 1200 x 2400 DPI and versatile functions like printing from and saving to USB flash drives and memory cards, the XP-630 offers comprehensive scanning and copying solutions. -
Eco-friendly choice
The ENERGY STAR certification of the XP-630 assures you of its energy efficiency, making it an environmentally friendly addition to your home or office.
- Epson Expression Premium XP-630 - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson Micro Piezo - 4-ink
- Max Printing Speed
- Up to 13 ppm (mono) / up to 10 ppm (colour)
- Max Printing Resolution
- Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Standard Media Capacity
- 100 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB, USB host, Wi-Fi
- AirPrint Enabled
- Office Machine Features
- Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive
- Power
- AC 230 V
- 39 cm x 34.1 cm x 13.8 cm
- 6.7 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Ink-jet - colour
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Supported Flash Memory
- SD Memory Card, USB flash drive, SDHC Memory Card, SDXC Memory Card
Printing
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 360 nozzles (black), 180 nozzles (per colour)
- Ink Cartridge Configuration
- 5 cartridges (1 each: cyan, magenta, yellow, black, photo balck)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black, photo black
- 4-ink
- Minimum Ink Droplet Size
- 1.5 pl
- Ink Type
- Epson Claria Premium Ink
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
Document & Media Handling
- Original Type
- Sheets
- Max Media Size
- A4/Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
- 100 sheets
- Input tray - 100 sheets , CD/DVD tray
- Speed Details
- Printing: up to 32 ppm - B/W , Printing: up to 32 ppm - colour , Printing: up to 13 ppm - B/W (ISO/IEC 24734) , Printing: up to 10 ppm - colour (ISO/IEC 24734) , Printing: 20 sec (10 x 15 cm (4"x6")) - photo
- 1 x USB , 1 x USB host - 4 pin USB Type A
- WEP, WPA-PSK, Wi-Fi Direct
- Operating System Support
- MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6.8 or later, Windows 8, MS Windows XP (32/64 bits)
- Software Included
- Drivers & Utilities, EPSON Print CD, Epson Easy Photo Print
- Voltage Required
- AC 230 V
- 18 Watt
- Power Consumption Standby
- 1.2 Watt
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (photo black)
- ENERGY STAR Certified
- 39 cm
- 34.1 cm
- 13.8 cm
- 6.7 kg
- Sound Emission
- 37 dBA (operating)
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £15.08 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.60 |
Epson A4 Iron On Transfer Pack 10sht | In Stock | £13.33 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.60 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £15.00 |
