Epson EB-X39 XGA 1024 x 768 3500 Lumens 3LCD Projector
Quicklinx: DBLLWS00 Mfr#: V11H855041
With the control of a host PC, up to 50 terminals can be connected via the multi-PC projection from a single projector. The host PC acts as a moderator, selecting media from up to four terminals to be projected simultaneously. With the moderator function, you can maintain control and prevent tampering with what's projected on screen.
Enjoy enhanced connectivity and flexibility with Wi-Fi connectivity. Easily share and transmit images, text and files from your smart devices using the "Epson iProjection" application for smooth and smart projections. And with an additional attachment piece holding the wireless LAN adaptor in place, your transmissions will never be interrupted.
Epson EB-X39 - 3LCD projector - portable - LAN - white grey
3LCD projector
White grey
Built-in Devices
Speaker
Brightness (White)
3500 lumens
Brightness (Colour)
3500 lumens
Contrast Ratio
15000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
UHE 210 Watt
Bulb life cycle
Up to 6000 hour(s) - normal mode , Up to 12000 hour(s) - economic mode
Video Input
RGB, composite video LAN
Speakers
Speaker(s) - integrated
309 Watt
30.2 cm x 24.9 cm x 9.2 cm
2.7 kg
3-year warranty
3LCD projector
Built-in Devices
Speaker
Ethernet
Enclosure Colour
White grey
Projector
Brightness (White)
3500 lumens
Brightness (Colour)
3500 lumens
Brightness (Reduced)
2230 lumens
Contrast Ratio
15000:1 (dynamic)
Image Size
76 cm - 762 cm
Throw Ratio
1.48 - 1.77:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
85 Hz
Bulb type
UHE 210 Watt
Bulb life cycle
sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, EPSON 3LCD technology, Split Screen, Direct Power On, Direct Power Off, Dynamic Mode, Theater Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.58-1.72
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
5 Watt
Speakers
1 x mixed channel
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone 3.5 mm , 1 x USB - 4 pin USB Type B , 1 x USB - 4 pin USB Type A , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 2 x audio line-in - mini-phone stereo 3.5 mm
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock
Power Source
AC
309 Watt
Power Consumption Stand by
0.2 Watt
Software Included
EasyMP Network Projection, EasyMP Multi PC Projection
30.2 cm
24.9 cm
9.2 cm
2.7 kg
Limited warranty - 3 years - on-site , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
37 dBA
28 dBA
