Epson EB-W31, Projector, Mobile/Nogaming, WXGA, 1280 x 800
Quicklinx: BZX6WS00 Mfr#: V11H730041
15 years worth of entertainment
With a long lamp and filter life, even if using the projector to watch a movie every day, it would be up to 15 years before either would need to be changed .
High-quality, bright images
Experience exceptional-quality images that are three times brighter than competitor products thanks to 3LCD technology and equally high White and Colour Light Output. View your content like never before and pick out even the finest detail with crisp, clear blacks creating clearly defined shadows, all thanks to a 15,000:1 contrast ratio.
The big picture
Able to take content from a range of sources and display it up to a massive 300 inches, the EB-W31 uses an HDMI inputs to allow users to broadcast high-quality digital video and audio content. You can even project photos and documents straight from a smartphone or tablet with Epson's iProjection app .
Everything included for fuss-free installation
An included carry case makes for easy movement of the projector from room to room. Horizontal and vertical keystone correction mean the projector can be installed in a number of places without distorting the image.
Eco-friendly features
By varying the lamp power according to what content is being displayed, the EB-W31 can help save energy, while eco-mode helps reduce power consumption and extend lamp life.
  • Images that look great
    When looking to deliver high-quality images - brightness is key - and this projector is no exception. A massive three times brighter than some competitor products.
  • Pick out the finest detail
    Don't settle for washed-out images; view your movies, games and presentations in more detail than ever before. The EB-W31 has a 15,000:1 contrast ratio to create crisp, clear blacks and clearly defined shadow detail to bring your content to life.
  • 15 years worth of entertainment
    Don't want to have to think about changing a lamp or filter? With the EB-W31, you won't have to worry about it as, even if you watch a film a day, they can both last up to 15 years.
  • The big picture
    Whether it's used for movies, viewing family photos, presentations – or all three – this projector offers users a truly big screen experience. Able to take content and display it at a massive 300+ inch size, it has an HDMI input to allow users to broadcast high quality digital video and audio content. For added versatility, users can even have the option to project photos and documents straight from a smartphone or tablet with Epson's iProjection app.
  • Fuss-free installation
    Quick and easy to install in any room of the house, this projector can be setup at a moment's notice, wherever you need it. A useful carry bag is included making it easy to travel between rooms, office floors or between home and work. Achieving a clear and properly aligned image without distortion is easy thanks to horizontal and vertical keystone correction and 1.2x optical zoom.
  • Eco-friendly features
    There are several ways this projector can help reduce costs. Eco-mode extends the life of the lamp, while an A/V mute option pauses the projector, saving power by dimming the lamp by 70%. By varying the lamp power according to what content is being displayed, the projector will automatically save energy.
  • Easy to live with
    A projector should never be complicated, and the EB-W31 includes an all-new, re-designed user interface and home screen for easy navigation and quick access of all its essential functions. Beautifully designed and with a compact footprint, it looks great in the office or the home and can help save on space.
Epson EB-W31 - 3LCD projector - portable
3LCD projector - 720p
Brightness (White)
3200 lumens
Brightness (Colour)
3200 lumens
Contrast Ratio
15000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
200 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video
Speakers
Speaker(s) - integrated
AC 120/230 V (50 - 60 Hz)
277 Watt
29.7 cm x 23.4 cm x 7.7 cm
2.4 kg
Projector
Brightness (White)
3200 lumens
Brightness (Colour)
3200 lumens
Brightness (Reduced)
2420 lumens
Contrast Ratio
15000:1 (dynamic)
Image Size
84 cm - 813 cm
Throw Ratio
1.3 - 1.56:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Bulb type
200 Watt
Bulb life cycle
sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, EPSON 3LCD technology, Split Screen, Direct Power On, Direct Power Off, Dynamic Mode, 3x Brighter Colors, MHL compliance
Lens
Focus Type
Manual
Lens Aperture
F/1.58-1.72
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, MHL
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - RCA x 2
Carrying case, wireless remote control
1 x VGA cable , 1 x USB cable
Security Features
Security lock slot (cable lock sold separately), password protection
Power Source
AC
277 Watt
Power Consumption Stand by
0.26 Watt
Software Included
EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
29.7 cm
23.4 cm
7.7 cm
2.4 kg
Limited warranty - 2 years - carry-in , Limited warranty - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
37 dBA
28 dBA
BZX6 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.58
