The Epson EB-G6350 boasts superior picture quality, ensuring the best possible projection for important presentations. The Colour Uniformity function compensates for unequal colour distribution by adjusting the intensity of RGB on individual areas of the screen.
New and innovative features are designed to offer the best possible presenting tools. The projector can be rotated vertically by 360 degrees so the projection image can be easily moved around the room.
The Epson EB-G6350 is easy to set up and use, thanks to a variety of user-friendly installation features. Pixel alignment, for example, enables the user to align pictures easily and effectively during set up for clear, correct images. With edge blending, a large, widescreen image can be projected from a number of projectors working together seamlessly. Its powerful zoom lens, as well as manual vertical keystone correction and centred lens, make it quick and easy to set up in a variety of positions without picture blurring or distortion.
The HDMI input provides the flexibility to connect to high definition devices, ensuring this projector is compatible with more input sources.
For simpler integration, this model is also compatible with the Epson EB-G5 series lenses .
Educational projector
Powerful 7,000-lumen EB-G6350 professional installation projector with XGA screen resolution to deliver sharper, clearer presentations.
- Epson EB-G6350 - 3LCD projector - LAN
- 3LCD projector
- Built-in Devices
- Speaker
- Brightness
- 7000 lumens
- Brightness (Colour)
- 7000 lumens
- Contrast Ratio
- 5000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- 380 Watt
- Bulb life cycle
- Up to 2000 hours - normal mode , Up to 4000 hours - economic mode
- Video Input
- RGB, S-Video, composite video, component video LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 542 Watt
- 40.6 cm x 50.5 cm x 17.1 cm
- 9.7 kg
- 3-year warranty
- 3LCD projector
- Built-in Devices
- Speaker
Projector
- Brightness
- 7000 lumens
- Contrast Ratio
- 5000:1
- Image Size
- 127 cm - 762 cm
- Projection Distance
- 1.3 m - 14.7 m
- Throw Ratio
- 1.29 - 2.35:1
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Bulb type
- 380 Watt
- Bulb life cycle
- sRGB colour profile, EPSON 3LCD technology, Crystal Clear Fine (C2 Fine), DICOM Simulation Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.65-2.55
- Zoom Type
- Manual
- Zoom Factor
- 1.8x
- Keystone Correction Direction
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
- Lens Shift Type
- Manual
- Vertical Lens Shift
- 57% / 57%
- Horizontal Lens Shift
- 30% / 30%
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, DisplayPort, component video, composite video, S-Video
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x DisplayPort - 20 pin DisplayPort , 1 x composite video input - RCA , 1 x component video input - BNC x 5 , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 3 x audio line-in - mini-phone stereo 3.5 mm
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), security label
- Voltage Required
- 542 Watt
- Power Consumption Stand by
- 0.41 Watt
- Software Included
- EasyMP Monitor
- 40.6 cm
- 50.5 cm
- 17.1 cm
- 9.7 kg
- Limited warranty - 3 years / 15000 hours - carry-in , Limited warranty - lamp - 3 years / 3000 hours
- 20 - 80%
- Sound Emission
- 37 dBA
- Sound Emission (Economic Mode)
- 31 dBA
