Epson EB-685WS WXGA 3LCD 3500 Lumens Projector
Quicklinx: FB5BWS00 Mfr#: V11H744340DA
With a brightness of 3,500 lumens and HD-ready WXGA resolution, the EB-685WS's ultra-short-throw design allows you to present large images from a very short distance with minimised shadows and glare. A 14,000:1 contrast ratio and HDMI input mean that students benefit from sharp, clear images, and SMART whiteboard compatibility allows for added interactivity.
  • High-quality, bright images
    Epson's 3LCD technology ensures high-quality images with equally high white and color light output for vivid colors and bright images, even in daylight, and three times brighter colors than leading competitive projectors.
  • Keep costs down
    Project for longer with improved reliability and a longer lamp life in Eco mode.
  • Enhanced learning
    Split-screen functionality allows two pieces of content to be displayed simultaneously without compromising on quality. The moderator function allows teachers to remain in control, choosing what content to display.
Epson EB-685WS - 3LCD projector - LAN - grey, white
3LCD projector - 720p
Grey, white
Built-in Devices
Speaker
Brightness (White)
3500 lumens
Brightness (Colour)
3500 lumens
Contrast Ratio
300:1 / 14000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
250 Watt
Video Input
RGB, composite video LAN
Speakers
Speaker(s) - integrated
AC 230V (50 - 60 Hz)
354 Watt
36.7 cm x 40 cm x 14.9 cm
5.7 kg
3-year warranty
Built-in Devices
Speaker
Ethernet
Enclosure Colour
Grey, white
Projector
Brightness (White)
3500 lumens
Brightness (Colour)
3500 lumens
Brightness (Reduced)
2900 lumens
Contrast Ratio
Image Size
152 cm - 254 cm
Projection Distance
0.4 m - 0.6 m
Throw Ratio
0.28:1
Digital Zoom Factor
1.35x
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Bulb type
250 Watt
sRGB colour profile, Blackboard Mode, EPSON 3LCD technology, Whiteboard Mode, Automatic Brightness Adjustment, Dynamic Lamp Control, Dynamic Mode, Theater Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.6
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-3 / +3
Horizontal Keystone Correction
-3 / +3
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, MHL
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x Mobile High-Definition Link (MHL) / HDMI , 2 x HDMI input - 19 pin HDMI Type A , 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15)
Wireless remote control, SMART Integrated IWB Cable
1 x USB cable
Mounting Kit
Included
Security Features
Security lock slot (cable lock sold separately), password protection
Power Source
AC
354 Watt
Power Consumption Stand by
0.39 Watt
Software Included
EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
36.7 cm
40 cm
14.9 cm
5.7 kg
Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
35 dBA
30 dBA
FB5B Epson ELPSP02 - Left / right channel speakers - 30 Watt (Total) In Stock £101.15
FB5B Epson Wireless Adaptor LAN B/G/N In Stock £99.78
