Epson EB-2155W WXGA 3LCD 5000 Lumens Projector
Quicklinx: DQW0WS00 Mfr#: V11H818041
Our super-bright new business projector offers an outstanding brightness of 5,000 lumens. The EB-2155W is designed to project a scalable image size of up to 300 inches, and offers connectivity options such as dual HDMI and stream and share wireless features using Epson's Multi-PC projection or the Epson iProjection App.
  • Bright and light
    Even though its light weight and compact size enable it to be carried from room to room, the projector is capable of highly visible images thanks to its high brightness and superior 15,000:1 contrast ratio. Room lights don't have to be dimmed to see bright and clearly projected images, allowing meeting participants to concentrate better for improved meeting productivity.
  • Multi-PC projection
    With the control of a host PC, up to 50 terminals can be connected via the multi-PC projection from a single projector. The host PC acts as a moderator, selecting media from up to 4 terminals to be projected simultaneously. With the moderator function, you can maintain control and prevent tampering with what's projected on screen.
  • Split screen
    Split screen allows inputs from two separate sources to be displayed side by side on the same screen. In a video conference, for example, images of presentation materials and remote participants can be shown simultaneously.
  • Real-time auto V and H keystone correction
    The projector is equipped with built-in camera to provide advanced, auto vertical and horizontal keystone correction. With this correction feature, you can conveniently position the projector anywhere in the room. Simply turn on the power and direct the projector towards the screen or wall, and the image will be automatically corrected in no time. With real-time keystone adjustment, this allows the projector to display the corrected image less than a second after detecting a projector motion. This adjustment speed lets you display a rectangular screen even while you are moving the projector.
  • Epson projector management
    With Epson's network monitoring and control software, you can see from a single PC which projectors are available and whether they are running efficiently even across the biggest networks. You can access, configure and control your projectors remotely, as well as receive instant email alerts for pre-defined critical indicators such as non-functioning devices or overheating lamps. Each projector's IP address can also be accessed remotely via LAN connection.
  • Wireless transmission
    Enjoy enhanced connectivity and flexibility with Wi-Fi connectivity. Easily share and transmit images, text and files from your smart devices using the "Epson iProjection" application for smooth and smart projections. And with an additional attachment piece holding the wireless LAN adapter in place, your transmissions will never be interrupted.
  • Gesture presenter
    Users can control their presentations conveniently by moving their hands to a white floating marker at the bottom right side of the projection screen. This simple gesture allows users to change to the next slide without using a clicker.
  • Home screen
    View and access your most frequently used functions immediately on the home screen. See all source information at a glance, no matter what the source input. With all the information you need right there on the home screen, wireless connections have never been easier.
  • Auto power on
    With the auto power on function, projection starts automatically once a projection signal is detected via VGA cable, HDMI cable and USB port. This provides an easy and hassle-free presentation.
  • Scheduler function
    Reduce power consumption and do your part for the environment with the schedule projector action. With this function, you can program the projector to automatically turn on and shut down at fixed times daily. Up to 30 programs can be set for this projector.
  • Light optimizer
    Save energy consumption and do your part for the environment with the Eco-friendly auto-brightness adjustment. The luminance sensor detects the brightness level of the environment and adjusts the projector's brightness automatically, giving you power and cost savings. This function can be turned on/ off according to your preference.
  • Longer lamp life
    With a long lamp life in Eco-mode, the frequency of costly lamp replacements is reduced, saving you time and money.
Epson EB-2155W - 3LCD projector - 802.11n wireless / LAN - white
3LCD projector - 720p
White
Brightness (White)
5000 lumens
Brightness (Colour)
5000 lumens
Contrast Ratio
400:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
300 Watt
Video Input
RGB, composite video IEEE 802.11n wireless / LAN
Speakers
Speaker(s) - integrated
AC 230V (50 - 60 Hz)
420 Watt
4.5 kg
3-year warranty
802.11b/g/n, Ethernet
Enclosure Colour
White
Projector
Brightness (White)
5000 lumens
Brightness (Colour)
5000 lumens
Brightness (Reduced)
3600 lumens
Contrast Ratio
400:1
Image Size
74 cm - 711 cm
Projection Distance
0.9 m - 8.5 m
Throw Ratio
1.38 - 2.24:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Bulb type
300 Watt
sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, Split Screen, DICOM Simulation Mode, Direct Power On, Direct Power Off, Dynamic Mode, Theater Mode, instant on/off
Lens
Focus Type
Manual
Lens Aperture
F/1.51-1.99
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, DisplayPort, composite video, MHL
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x DisplayPort , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI
Wireless remote control, wireless LAN unit
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
Power Source
AC
420 Watt
Power Consumption Stand by
0.5 Watt
Software Included
EasyMP Network Projection, EasyMP Slide Converter, EasyMP Monitor, EasyMP Multi PC Projection
4.5 kg
Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours
5 °C
20 - 80%
Sound Emission
39 dBA
29 dBA
DQW0 Epson ELPMB23 Projector Mount In Stock £109.44
DQW0 Epson Wireless Adaptor LAN B/G/N In Stock £101.99
