Epson EB-2142W WXGA 3LCD 4200 Lumens projector
Quicklinx: FB5QWS00 Mfr#: V11H875041
Up to 280-inch display and outstanding quality
HD-ready WXGA resolution combined with Epson's 3LCD technology ensures high-quality content has more vivid colours and brighter images. HDMI connectivity guarantees sharper and clearer content, even at the maximum image size of 280 inches.
Simple set-up and connectivity
Offers auto power-on and an array of connectivity options including two HDMI connections and built-in wireless LAN connectivity to stream content from laptops or mobile devices. Compatible with iProjection software for easy connectivity and content sharing.
Keep costs down
Project for longer with improved reliability and a longer lamp life of up to 12,000 hours in eco mode.
Home screen
The home screen offers quick and easy access to a variety of useful functions, such as choosing connection sources. Wireless connections can also be made easily using the information on screen.
Value added flexibility
The Multi-PC projection software bundled with the EB-2142W makes it possible to connect with up to 50 computers and partition the screen for split-screen projection capability - offering far better cost-effectiveness and flexibility than a flat-panel display.
  • Affordable business projector
    Deliver great presentations with a display solution that offers a great brightness of 4,200 lumens and a scalable image size of up to 280 inches.
Epson EB-2142W - 3LCD projector - LAN - white
3LCD projector - 720p
White
Built-in Devices
Speaker
Brightness (White)
4200 lumens
Brightness (Colour)
4200 lumens
Contrast Ratio
15000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
230 Watt
Bulb life cycle
Up to 6000 hour(s) - normal mode , Up to 12000 hour(s) - economic mode
Video Input
LAN
Speakers
Speaker(s) - integrated
AC 230V (50 - 60 Hz)
331 Watt
30.9 cm x 28.2 cm x 9 cm
3.1 kg
3-year warranty
Built-in Devices
Speaker
Ethernet
Enclosure Colour
White
Projector
Brightness (White)
4200 lumens
Brightness (Colour)
4200 lumens
Brightness (Reduced)
2400 lumens
Contrast Ratio
15000:1 (dynamic)
Image Size
74 cm - 711 cm
Projection Distance
0.9 m - 8.5 m
Throw Ratio
1.38 - 2.24:1
Digital Zoom Factor
1.6x
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz
Bulb type
230 Watt
Bulb life cycle
sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, EPSON 3LCD technology, Direct Power On, Direct Power Off, Dynamic Mode, Theater Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.51-1.99
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-20 / +20
Video Input
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x microphone input - mini-phone 3.5 mm
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock
Power Source
AC
331 Watt
Power Consumption Stand by
2 Watt
Software Included
EasyMP Multi PC Projection
30.9 cm
28.2 cm
9 cm
3.1 kg
Limited warranty - 3 years / 8000 hours , Limited warranty - lamp - 1 year / 1000 hours
5 °C
35 °C
20 - 80%
Sound Emission
37 dBA
28 dBA
FB5Q Epson Wireless Adaptor LAN B/G/N In Stock £99.78
