Epson ColorWorks TM-C3500 Colour DURABrite Ultra Inkjet Label Printer
Quicklinx: 9JWFWS00 Mfr#: C31CD54012CD
Print your own labels
With the ColorWorks C3500 (TM-C3500), you can easily customise and print your own colour labels. Whether it's printing packaging labels with colourful logos and pictures or tickets and ID cards with important barcodes and product information, this printer ensures you can print it all from one machine. It also helps you conform with GHS international chemical labelling guidelines, as labels can be printed on-demand without using pre-printed templates.
High-quality and durable
Thanks to the individual pigment ink cartridges, you can create fast-drying, highly detailed labels that are smudge, water and fade resistant. Not only will your labels look great, but the pigment ink's long-lasting, durable qualities make it perfect for a wide variety of environments.
Easy-to-use 4-colour label printer
You can easily print on a wide selection of materials, including matte and glossy coated paper and filmic labels. This means you can create exactly the type of labels you need. The LCD screen displays ink levels and printer status information, while front operation and easy setup software means you can operate the printer without specialist training.
Saving you money
Thanks to individual pigment ink cartridges, this label printer is ideal for cutting printing costs with its low cost-per-label, as you only need to replace the colour used.
  • Colour label printer
    The high-speed, high-quality colour label printer, designed to print a wide variety of labels in-house with a low cost-per-label.
Epson TM C3500 - label printer - colour - ink-jet
Printer Type
Label printer - ink-jet - colour
12 kg
Inkjet Technology
Epson Micro Piezo
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Max Media Size
Continuous paper 30 mm - 112 mm (width)
Min Media Size (Custom)
30 mm
Max Media Size (Custom)
112 mm
Print Speed
Up to 103 mm/sec
Max Resolution (B&W)
720 x 360 dpi
Cutter
LAN, USB host
Media Type
Labels, continuous paper labels, die cut labels
Black Mark sensor
Print server
Microsoft Certification
Compatible with Windows 7
1-year warranty
31 cm x 28.3 cm x 26.1 cm
Printer Type
Printer
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
4 x 360 nozzles (black, cyan, magenta, yellow)
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Type
Epson DURABrite Ultra inks
Print Speed
Up to 103 mm/sec - 360x360 dpi
Built-in Devices
Status LCD
Wired
LAN, USB host
720 x 360 dpi
Black Mark sensor
Auto Cutter
Media Handling
Media Type
Max Media Size
30 mm
112 mm
Max Printing Width
104 mm
Roll Maximum Outer Diameter
101.6 mm
Print server
1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (yellow) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink maintenance kit
Media Included
Roll of media
MTBF
88,000 hour(s)
Power adapter - external
Frequency Required
50 - 60 Hz
30 Watt
Power Consumption Stand by
3 Watt
Software Included
Drivers & Utilities
Limited warranty - 1 year - carry-in
10 °C
35 °C
20 - 80%
31 cm
28.3 cm
26.1 cm
12 kg
Width (Shipping)
44 cm
Depth (Shipping)
40 cm
Height (Shipping)
42.5 cm
Weight (Shipping)
15.04 kg
