Epson AcuLaser C2900N A4 Colour Laser Printer
Quicklinx: 8CM6WS00 Mfr#: C11CB74001BY
High-quality results at speed: Increase the productivity of your business by printing at high speeds of up to 23 pages per minute in both mono and colour, while ensuring your text and graphics documents are crisp and vibrant with a print resolution of up to 600 x 600dpi.
Effortless integration: Designed to fit seamlessly into complex IT environments, the AcuLaser C2900N comes network-ready with numerous interfaces and emulations for easy integration, including Gigabit Ethernet, IPv6, Adobe PostScript 3 and PCL 5c/6.
Customise your printer: You can choose from a variety of options to fit your business needs. Make your printer even more productive with an additional 250-sheet paper tray to increase capacity to 500 sheets, while optional double-sided printing can cut paper use and costs by up to 50 percent. A high standard memory of 256MB can be increased by an additional 512MB to further boost performance.
Economical printing: The AcuLaser C2900N offers great value for money and its ENERGY STAR-qualified reduced power consumption helps businesses to further cut total cost of ownership and environmental impact.
  • High-quality results at speed
    Increase the productivity of your business by printing at high speeds of up to 23 pages per minute in both mono and color, while ensuring your text and graphics documents are crisp and vibrant with a print resolution of up to 600 x 600dpi.
  • Effortless integration
  • Customise your printer
  • Economical printing
Epson AcuLaser C2900N - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
18.4 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
220 mm x 355.6 mm
Print Speed
Up to 23 ppm - B/W , Up to 23 ppm - colour
Max Resolution (B&W)
600 dpi
Max Resolution (Colour)
600 dpi
USB, Gigabit LAN
400 MHz
RAM Installed (Max)
256 MB (768 MB)
Language Simulation
PCL 5C, PostScript 3, PCL 6
Media Type
Envelopes, plain paper
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray, 1-sheet multipurpose tray
Monthly Duty Cycle (max)
40000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet - integrated
Printer Features
Optional duplex
Apple MacOS X 10.4.11 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
1-year warranty
40.4 cm x 46.9 cm x 41.6 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB, Gigabit LAN
600 dpi
600 dpi
First Print Out Time B/W
15.5 sec
First Print Out Time Colour
15.5 sec
Language Simulation
Fonts Included
81 x scalable PCL , 136 x PostScript
Printer Features
Optional duplex
Media Handling
400 MHz
RAM
RAM Installed (Max)
256 MB / 768 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
220 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 216 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) , 1 x manual - 1 sheet - 220 x 355.6 mm weight: 60 g/m² - 216 g/m²
Max Media Capacity
500 sheets
Output Trays Capacity
150 sheets
Duty Cycle
40000 pages
Print server - integrated
Network / Transport Protocol
TCP/IP, LPR/LPD, SMTP, BOOTP, DHCP, RARP, Bonjour, DDNS
Remote Management Protocol
SNMP 1, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS
Expansion Slots
1 x Gigabit LAN - RJ-45 , 1 x USB
Consumables Included
1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19798/24712 , 1 x toner cartridge (cyan) - up to 1000 pages ISO/IEC 19798/24712 , 1 x toner cartridge (magenta) - up to 1000 pages ISO/IEC 19798/24712 , 1 x toner cartridge (yellow) - up to 1000 pages ISO/IEC 19798/24712
EN 61000-3-2, EN55022, IEC 61000-4-11, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN 61000-3-3, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1
Power supply - internal
Frequency Required
50/60 Hz
365 Watt
Power Consumption Stand by / Sleep
60 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site
10 °C
32 °C
10 - 85%
Sound Emission (Idle)
28 dBA
Sound Emission (Operating)
53 dBA
40.4 cm
46.9 cm
41.6 cm
18.4 kg
8CM6 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
8CM6 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
