Promising long-life laser projection for large venues, this 6,000 lumens WUXGA projector delivers rich, vivid colors thanks to Epson's 3LCD technology and equally high White and Color Light Output. With flexible installation and low maintenance, this 4K enhanced projector offers a fit-and-forget solution for scenarios in which only superior projections will do.
Laser-sharp images
Ensure superb quality and the best possible delivery of presentations with this laser installation projector for large venues. Featuring 3LCD technology and equally high White and Colour Light Output, its WUXGA resolution images are vivid and bright, even in daylight. Including a newly developed inorganic phosphor wheel, the projector offers superior light and heat resistance to deliver excellent reliability. For a next-level viewing experience, the projector features 4K enhancement, giving images exceptional sharpness and clarity that lasts for up to 83,000 hours thanks to a long laser life. A built-in camera is also included to ensure accurate image calibration. -
Flexible positioning
Thanks to a new range of motorised lenses, including optional ultra-short throw (UST) lens, the projector benefits from true 360° installation flexibility, allowing it to be placed virtually anywhere - without loss of brightness or distortion of image. -
Quick set-up
Get started quickly thanks to a lens memory function, which stores projector settings such as image position, focus and zoom, for prompt access when projecting images in different aspect ratios, or using different lenses. A split-screen mode also allows dual feeds to be projected.
- Epson EB-L1100U - LCD projector - LAN - white
- LCD projector - 1080p
- White
- Built-in Devices
- Speaker
- Brightness (White)
- 6000 lumens
- Brightness (Colour)
- 6000 lumens
- Contrast Ratio
- 2000:1 / 25000000:1 (dynamic)
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Lens Shift Direction
- Horizontal, vertical
- Bulb life cycle
- Up to 20000 hour(s) - normal mode , Up to 30000 hour(s) - economic mode
- Video Input
- RGB LAN
- Power
- AC 120/230 V (50 - 60 Hz)
- 454 Watt
- 58.6 cm x 49.2 cm x 21.1 cm
- 20 kg
- 5-year warranty (Netherlands, Belgium - 5 years)
- Built-in Devices
- Speaker
- Networking
- Ethernet
- Enclosure Colour
- White
Projector
- 6000 lumens
- 6000 lumens
- Brightness (Reduced)
- 4200 lumens
- Contrast Ratio
- Image Size
- 127 cm - 762 cm
- Projection Distance
- 1.5 m - 15.1 m
- Throw Ratio
- 1.44 - 2.32:1
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- 16:10
- Colour Support
- Bulb life cycle
- sRGB colour profile, DICOM Simulation Mode, Dynamic Mode, Auto Calibration
Lens
- Focus Type
- Powered
- Lens Aperture
- F/1.7-2.3
- Zoom Type
- Powered
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Vertical Keystone Correction
- -45 / +45
- Horizontal Keystone Correction
- -30 / +30
- Vertical Lens Shift
- 67% / 67%
- Horizontal Lens Shift
- 30% / 30%
Video Input
- Analogue video Signal
- RGB
- Video Interfaces
- VGA, HDMI, DVI
- LAN and Wireless Image Transferring Protocols
- Wired LAN
- 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x USB 2.0 - 4 pin USB Type B (management) , 3 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x HDMI input - 19 pin HDMI Type A , 1 x DVI-D , 1 x HDBaseT - RJ-45 , 1 x component video output - BNC x 5
- Included Accessories
- Cable cover, remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- Security Slot Type
- Kensington security slot
- Power Source
- AC
- Voltage Required
- 454 Watt
- Power Consumption Stand by
- 0.5 Watt
- Software Included
- EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
- 58.6 cm
- 49.2 cm
- 21.1 cm
- 20 kg
- Limited warranty - 5 years / 20000 hours
- Regional Warranty Exceptions
- Netherlands, Belgium - 5 years
- Sound Emission
- 34 dB
- Sound Emission (Economic Mode)
- 28 dB
Epson Wireless Adaptor LAN B/G/N | In Stock | £98.83 |
