Energizer UE2601 2600mAh Portable Charger Black
Quicklinx: BTVQWS00 Mfr#: UE2601
Energizer® UE2601 is a small cylinder shaped viewing stand and battery charger with a small, extendable rubber slip mat for propping up smarthphones and other media devices while charging.
Portability
Small and light weight, the cylinder shaped design easily fits in a pocket, purse, or bag, making it extremely portable for on-the-go charging.
Viewing Stand
Built-in, extendable rubber slip mat creates an all-in-one viewing stand and charger by securely propping up your smartphone while you charge.
Powerful
2,600 mAh of power provides a strong boost of power for watching movies, viewing presentations, sharing pictures, and much more.
Style
Hard plastic housing provides sturdy protection against drops and falls while a glossy finish and metallic end caps display the modern sophistication associated with the Energizer® brand.
Safety Technologies
Backed by the Energizer brand, UE2601 comes standard with state-of-the-art, XPAL Inside™ safety technologies for a trusted charge that won’t damage your device
Specs
Battery Type - Lithium-ion
Battery Capacity - 2600 mAh
Input Specification - DC 5V, 1A
Output Specification - DC 5V, 1A
Weight - 68g
Dimensions - 96.2(L) x 26(W) x 26(H)mm
  • Portability
  • Viewing stand
  • Powerful
  • Style
    Hard plastic housing provides sturdy protection against drops and falls while a glossy finish and metallic end caps display the modern sophistication associated with the Energizer brand.
  • Safety technologies
    Backed by the Energizer brand, UE2601 comes standard with state-of-the-art, XPAL Inside safety technologies for a trusted charge that won't damage your device.
Energizer UE2601 power bank - Li-Ion - USB
Power bank
2.6 cm x 9.62 cm x 2.6 cm
68 g
Output Connector Type
USB - on cable: Micro-USB
5 V
Voltage Provided
5 V
Max Electric Current
1 A
Lithium Ion - 2600 mAh
Cables
Micro-USB to USB cable
Power bank
Mobile phone
2.6 cm
9.62 cm
2.6 cm
68 g
Enclosure Colour
5 V
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
1 A
Phone stand
Lithium Ion
2600 mAh
