Elite Screens Manual Pull Down 150" (381cm) White
Quicklinx: CXZKWS00 Mfr#: M150XWV2
The Elite Manual Pull-down Series front projection screen is a cost effective retractable screen with a dual case design for wall or ceiling installation.
Elite Screens’ MaxWhite Screen Material is durable for daily use and easy to clean. It has a wide viewing angle with 1.1 Gain and is suitable for most applications including Commercial /Educational and Residential. MaxWhite Screen material has a black backing to eliminate light penetration for superior color reproduction. Its Texture pattern eliminates Moiré or Hot Spotting which is a common phenomenon with poorly made projection screen material or wall projections.
Size and Aspect Ratio
  • 4:3 Aspect Ratio
  • 150" Diagonal Viewing Size (120.0"W x 90.0"H)
Screen Material
  • MaxWhite 1.1 Gain Screen Material is durable and easy to clean
  • 160 degree wide viewing angle for commercial and residential presentations
  • Black backed screen material eliminates light penetration for superior color reproduction
  • Black masking enhances picture contrast
Casing & Installation
  • Durable metal casing - White
  • Suitable for wall/ceiling installations
  • Optional 6" - 18" brackets available
Control System
  • Auto-locking mechanism with variable height settings
  • Manually operated (lanyard included)
Quality & Reliability
  • Premium 2-Year Parts and Labor Warranty
  • 3-Year Warranty for Government, Education, Military and Religious
Certifications
  • GREENGUARD® Indoor Air Quality and GREENGUARD® Children & Schools Certi?ed
Elite Screens Manual Series M150XWV2 - projection screen - 150" (381 cm)
Projection screen
Placing / Mounting
In-ceiling mountable, wall mountable
White
Projection Screen Image Diagonal Size
150" (381 cm)
Projection Image Size
305 cm x 229 cm
Aspect Ratio
4:3
Screen Surface
MaxWhite
Product Material
Steel
16 kg
Projection screen
Placing / Mounting
Image Diagonal Size
150" (381 cm)
Image Width
305 cm
Image Height
229 cm
Screen Surface
MaxWhite
Aspect Ratio
4:3
Gain
1.1x
Viewing Angle
160°
Extra Border Size
10.2 cm (top)
Mildew-resistant, washable, black backing, black borders, pull down
Product Material
Steel
16 kg
White
Limited warranty - parts and labour - 2 years
