Eve Weather
Live smarter by knowing more about the place you care about most. Eve Weather senses temperature, humidity and air pressure. Easily access your personal weather data at your actual home, right on your iPhone and iPad.
Taking advantage of Apple's revolutionary HomeKit technology, Eve offers unparalleled ease of use, advanced security, and tight integration with Siri. Eve Weather is powered by long-lasting, replaceable batteries, so you don't even have to deal with power cords.
About Eve
With Eve, see your home at a glance, right on your iPhone and iPad. The Eve family of HomeKit accessories gathers data on air quality, temperature, humidity, air pressure, energy consumption and more. Gain insights that help you improve your comfort, and make your home a smarter place. Use the free Eve app to view all data collected by Eve and control all accessories featuring HomeKit technology.
- Know your home: Eve Weather senses temperature, humidity and air pressure
- Improve your comfort: your personal weather data at your actual home
- Gain insights: your personal data by day, month or year
- HomeKit-enabled: unparalleled ease of use and advanced security
- Works with Siri: ask for temperature and humidity
- Truly wireless: powered by long-lasting, replaceable batteries
- Easy setup: direct connection using Bluetooth Smart technology, no hub or gateway required
- Eve Weather - multipurpose sensor - Bluetooth 4.0
- Product Type
- Multipurpose sensor
- Environment
- Outdoor
- Sensor Type
- Temperature, humidity, air pressure
- Connectivity
- Wireless - Bluetooth 4.0
- Supported Host Device OS
- iOS
- 7.9 cm x 3.2 cm x 7.9 cm
- Product Type
- Sensor Type
- Environment
- Outdoor
- Connectivity Technology
- iOS
- Water-resistant
- Included Accessories
- 2 AA batteries
- IPX3
- 7.9 cm
- 3.2 cm
- 7.9 cm
- -18 °C
- 55 °C
- 0 - 100%
