Live smarter by knowing more about the place you care about most. With Eve Room, Eve senses indoor air quality, temperature, and humidity.
See your home at a glance, and view beautiful graphs by day, month or year. Gain insights that help you improve your comfort, and make your home a smarter place.
Improve your comfort
Live smarter by knowing more about the place you care about most. With Eve Room, Eve senses indoor air quality, temperature, and humidity. -
Gain insights
See your home at a glance, and view beautiful graphs by day, month or year. Gain insights that help you improve your comfort, and make your home a smarter place. -
Air quality beyond CO2
Eve Room is powered by a sophisticated sensor analyzing volatile organic compounds (VOCs). Air quality can vary based on many factors, and Eve Room goes beyond CO2 by analyzing substances that directly affect your well-being. Here is how it works. -
Easy setup
Eve connects directly to your iPhone or iPad using Bluetooth Smart technology, without requiring a hub, gateway or bridge. -
Advanced security
HomeKit technology provides advanced security with end-to-end encryption and authentication between Eve and your iPhone, iPad, or iPod touch. -
Simply elegant
The Eve family has been carefully designed to seamlessly blend into your home environment. This elegance extends to truly wireless operation: thanks to Bluetooth Smart technology, Eve is powered by long-lasting, replaceable batteries, so you don't even have to deal with power cords.
- Eve Room - multipurpose sensor - Bluetooth 4.0
- Product Type
- Multipurpose sensor
- Environment
- Indoor
- Functions
- Temperature measuring, humidity measurement, CO2 emissions measuring
- Power Source
- Battery
- Internet of Things (IoT) Platform
- Apple HomeKit
- Intelligent Assistant
- Siri
- Connectivity
- Wireless - Bluetooth 4.0
- Supported Host Device OS
- iOS
- Display
- E Ink - monochrome
- 1-year warranty
- 5.4 cm x 1.5 cm x 5.4 cm
- Product Type
- Environment
- Indoor
- Functions
- Power Source
- Battery
- Connectivity Technology
- iOS 11.4 or later
- Display
- Display Resolution
- 200 x 200 pixels
- Internet of Things (IoT) Compatible
- Platform
- Apple HomeKit
- Communications Type
- Product-to-product
- Communications Technology
- Bluetooth Low Energy (LE)
- Siri
- Battery Included
- Product Material
- Aluminium
- Warranty
- 1-year warranty
- 5.4 cm
- 1.5 cm
- 5.4 cm
- 0 °C
- 50 °C
- 5 - 95%
