eve room Wireless Indoor Sensor
Improve your comfort.
Live smarter by knowing more about the place you care about most. With Eve Room, Eve senses indoor air quality, temperature, and humidity.
Gain Insights.
See your home at a glance, and view beautiful graphs by day, month or year. Gain insights that help you improve your comfort, and make your home a smarter place.
Air Quality beyond CO2.
Eve Room is powered by a sophisticated sensor analyzing volatile organic compounds (VOCs). Air quality can vary based on many factors, and Eve Room goes beyond CO2 by analyzing substances that directly affect your well-being.
HomeKit-enabled.
Easy Setup
Eve connects directly to your iPhone or iPad using Bluetooth Smart technology, without requiring a hub, gateway or bridge.
Use your voice
Use Siri on your iPhone, iPad, or iPod touch to ask for temperature or humidity.
Advanced Security
HomeKit technology provides advanced security with end-to-end encryption and authentication between Eve and your iPhone, iPad, or iPod touch.
Simply elegant.
The Eve family has been carefully designed to seamlessly blend into your home environment. This elegance extends to truly wireless operation: thanks to Bluetooth Smart technology, Eve is powered by long-lasting, replaceable batteries, so you don't even have to deal with power cords.
Requirements
Eve requires an iPhone, iPad, or iPod touch with iOS 10.3 or later. To control this HomeKit-enabled accessory, iOS 10 or later is recommended. Controlling this HomeKit-enabled accessory automatically and away from home requires an Apple TV with tvOS 10 or later or an iPad with iOS 10 or later set up as a home hub.
Operating Range
0°C - 55°C / 32°F - 130°F
5% - 95% Humidity
Accuracy
± 0.3°C / ± 0.54°F
± 3% Humidity
3 x AA Replaceable Batteries
Wireless Connection
Bluetooth Low Energy
Dimensions
79 x 79 x 32 mm / 3.1 x 3.1 x 1.3 in
Live smarter by knowing more about the place you care about most. With Eve Room, Eve senses indoor air quality, temperature, and humidity. -
Gain insights
See your home at a glance, and view beautiful graphs by day, month or year. Gain insights that help you improve your comfort, and make your home a smarter place. -
Air quality beyond CO2
Eve Room is powered by a sophisticated sensor analyzing volatile organic compounds (VOCs). Air quality can vary based on many factors, and Eve Room goes beyond CO2 by analyzing substances that directly affect your well-being. Here is how it works. -
Easy setup
Eve connects directly to your iPhone or iPad using Bluetooth Smart technology, without requiring a hub, gateway or bridge. -
Advanced security
HomeKit technology provides advanced security with end-to-end encryption and authentication between Eve and your iPhone, iPad, or iPod touch. -
Simply elegant
- Eve Room - multipurpose sensor - Bluetooth 4.0
- Product Type
- Multipurpose sensor
- Functions
- Temperature measuring, humidity measurement, CO2 emissions measuring
- Power Source
- Battery
- Connectivity
- Wireless - Bluetooth 4.0
- Supported Host Device OS
- iOS
- 7.9 cm x 3.2 cm x 7.9 cm
- Product Type
- Functions
- Power Source
- Battery
- Connectivity Technology
- iOS
- Form Factor
- AA type
- Required Qty
- 3
- 7.9 cm
- 3.2 cm
- 7.9 cm
- 0 °C
- 55 °C
- 5 - 95%
