Elgato Eve Door & Window Sensor - wireless - Bluetooth 4.0 LE
Quicklinx: CYTWWS00 Mfr#: 1ED109901001
eve door & window - Wireless Contact Sensor
Improve your comfort.
Live smarter by knowing more about the place you care about most. With Eve Door & Window, Eve understands whether your door or window is open or closed.
Be informed.
See your home at a glance, and view beautiful graphs by day, month or year. Receive notifications about the status of your access points and know when your door or window has been opened. And with Apple TV at home, be alerted while you’re at work or on vacation.
Set Scenes
Automatically control other HomeKit-enabled accessories when you open or close a door or window. Create rules that automate your home, like setting the "I’m Home" scene when your door is opened after 6:00 p.m.
HomeKit-enabled.
Easy Setup - Eve connects directly to your iPhone or iPad using Bluetooth low energy technology, without requiring a hub, gateway or bridge.
Remote Access - You don’t even have to be home to monitor Eve. All you need is an Apple TV, and you’re ready to remotely check the status of your home at a glance.
Advanced Security - HomeKit technology provides advanced security with end-to-end encryption and authentication between Eve and your iPhone, iPad, or iPod touch.
Simply elegant.
The Eve family has been carefully designed to seamlessly blend into your home environment. This elegance extends to truly wireless operation: thanks to Bluetooth Smart technology, Eve is powered by long-lasting, replaceable batteries, so you don't even have to deal with power cords.
  • Improve your comfort
  • Gain insights
    See your home at a glance, and view beautiful graphs by day, month or year. Gain insights that help you improve your comfort, and make your home a smarter place.
  • Easy setup
    Eve connects directly to your iPhone or iPad using Bluetooth Smart technology, without requiring a hub, gateway or bridge.
  • Use your voice
    Use Siri on your iPhone, iPad, or iPod touch to ask for the current door or window state.
  • Advanced security
  • Simply elegant
Eve Door & Window - door and window sensor - Bluetooth 4.0
Door and window sensor
Environment
Indoor
Power Source
Internet of Things (IoT) Platform
Apple HomeKit
Wireless - Bluetooth 4.0
Supported Host Device OS
iOS
1-year warranty
5.2 cm x 2.4 cm x 2.3 cm
Environment
Indoor
Power Source
Apple iOS 9.1 or later
iOS
Platform
Apple HomeKit
Communications Type
Product-to-product
Communications Technology
Bluetooth Low Energy (LE)
1/2 AA type
Required Qty
1
Warranty
1-year warranty
5.2 cm
2.4 cm
2.3 cm
