Have a sprinkler turn on exactly when needed, automatically. Or activate your irrigation from anywhere, and leave it be. Eve Aqua converts your outdoor faucet into an intelligent water outlet. So you can keep your garden green, with little to zero effort.
Control with a touch, your voice or iPhone
Sure, you can water whenever you want with a touch of the onboard button - but it's all the more satisfying to control Eve Aqua with your iPhone, iPad, Apple Watch and even using Siri. -
Automatic irrigation using schedules
Eve Aqua takes care of the hard task while you relax in your garden. Simply add schedules to water automatically at regular times for a set period. As schedules are stored directly on Eve Aqua, they can be run at any time - no matter if Eve Aqua is connected to your iPhone or the Internet, and all without requiring a bridge or gateway. -
Far-reaching with a big future ahead
Eve Aqua supports Bluetooth and Thread, and joins the Thread network automatically. Thread makes your smart home network more responsive, robust, and increases its reach - the only thing else you need is HomePod mini. Thread is also a pillar of the new Matter standard. -
Hassle-free set up for any scenario
Eve Aqua is compatible with all popular hose systems and multi-channel water distributors, such as from Gardena or Kärcher, and installs in a matter of minutes. It's also ideal for more complex watering tasks, with the Eve app enabling you to set up to seven individual daily watering periods to suit each day. -
Auto shut-off
Never watch the clock, or flood your garden, again. Simply start watering, and Eve Aqua will shut off the water flow automatically after your set duration. -
Access on the go
On vacation and seen on the weather report that a heatwave's about to hit at home? Not a problem. With a home hub - HomePod, HomePod mini, or Apple TV - you're always connected to Eve Aqua and you can water your garden or plants really easily on the go. And if the weather does turn out to be wetter than forecast, you can pause schedules whenever you want, wherever you are. -
Enjoy your garden
Eve Aqua is built to live autonomously. IPX4 water resistance and Australian-certified UV protection keeps Eve Aqua shipshape season after season. Set up Eve Aqua once and never touch it again. If you can resist the temptation.
- Eve Aqua - smart water controller
- Product Type
- Smart water controller
- Package Content
- 2 AA batteries, hose connector
- Platform
- Apple HomeKit
- Communications Technology
- Bluetooth Low Energy (LE), Thread
- Supported Host Device Platform
- iOS
- IPX4
- Input
- Internal thread - 3/4"
- Output
- Fitting
- Product Type
- Package Content
- Autonomous schedules, child lock, water consumption monitor, 7 watering cycles per day, UV protection
Watering
- Operating Pressure
- 1-5 bar
- Input
- Output
- Fitting
- Form Factor
- AA type
- Required Qty
- 2
Internet of Things (IoT)
- Platform
- Apple HomeKit
- Intelligent Assistant
- Siri
- Compatible Application
- EVE app
- iOS
- IPX4
- 12.3 cm
- 8 cm
- 9.4 cm
