Edimax Wireless USB/Pll Print Server
Quicklinx: 762XWS00 Mfr#: PS-3207UWG
The print server's easy-to-use windows installation wizard enables a quick installation and setup. The print server can also be conveniently configured from any network client that supports web browsing.
Supports both Peer-to-Peer and Server-based printing. LAN clients can connect directly with the print server to execute printing jobs (Peer-to-Peer printing); or they can send printing tasks to a server first (queuing jobs) and allow the server to connect with the print server to execute the printing jobs (Server-based printing).
The print server provides LPR, IPP, Raw Printing and UNIX Logical Printer printing methods. You can choose the best printing method that is suitable for your environment.
The print server is compatible with all major operating systems used today.
The printer server can act as a DHCP server, allowing your LAN clients to automatically obtain an IP address or it can act as a DHCP client allowing a easy integration to your existing network.
This print server supports USB 2.0 High Speed, which increases the throughput when connected to USB 2.0 printers.
Edimax PS-3207UWg - print server - USB 2.0 / parallel - 10/100 Ethernet
Print server
External
Interface (Bus) Type
USB 2.0 / parallel
Ports
10/100 Ethernet
18.7 cm x 10 cm x 3 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN, 802.11b/g
Network / Transport Protocol
TCP/IP, IPX/SPX, AppleTalk, NetBEUI/NetBIOS, LPR/LPD
RAM
16 MB
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows Server 2003, Microsoft Windows 98/ME/NT/2000/XP
Print server
External
USB 2.0 / parallel
Ports
10/100 Ethernet
Wireless, wired
Cabling Type
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Remote Management Protocol
IPP, HTTP
DHCP support, auto-uplink (auto MDI/MDI-X), firmware upgradable
Aerial
Antenna
External detachable
Processor / Memory
RAM
16 MB
Flash Memory
2 MB
1 x 100Base-TX - RJ-45
2 x USB 2.0 - 4 pin USB Type A , 1 x parallel - 25 pin D-Sub (DB-25)
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA-PSK
FCC Class B certified, ISO 9001
Power adapter - external
18.7 cm
10 cm
3 cm
55 °C
10 - 90%
