Lexmark MarkNet 8352 Wireless Print Server
Quicklinx: CCC0WS00 Mfr#: 27X0225
  • IEEE 802.11n
Place assets where they are needed - printer location is functionally and economically driven, not constrained by existing LAN connections. SNMPv3 supports encrypted and authenticated management traffic protecting remote configuration and device status messages. IPSec can be used with both TCP/IP IPv4 and IPv6 networks and provides encryption and authentication of communications at the network layer.
A print server to connect to most major wireless networks via the 2.4 GHz band using one RP-SMA connector with antenna.
  • Freedom
  • Easy setup
    Wired and wireless configuration - configure using a USB cable or without any cables.
  • Embedded web page
    The embedded web page allows administrators to flash update printer firmware or access printer settings using a web browser to easily monitor printer status and change default settings.
  • Network communications security
Lexmark MarkNet N8350 - print server
Print server
802.11b/g/n
Data Transfer Rate
72 Mbps
Network / Transport Protocol
TCP/IP, AppleTalk, UDP/IP, NTP, ICMP/IP, IPSec, LPR/LPD, ARP, FTP, BOOTP, DHCP, DNS, RARP, Bonjour, SLP, DDNS
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n
Apple MacOS X, HP-UX 11.11, Novell NetWare 6.5, Novell NetWare 5.1 SP6 or later, Novell NetWare 6.0 SP3 or later, HP-UX 11.23, IBM AIX 5.3, SunSoft Solaris x86 10, Red Hat Enterprise Linux WS 4, Novell Open Enterprise Server, SuSE Linux Enterprise Server 11, Microsoft Windows Server 2008 R2, SUSE Linux Enterprise Desktop 11, Debian GNU/Linux 5.0, SUSE Linux Enterprise Desktop 10, SuSE Linux Enterprise Server 10, Red Hat Enterprise Linux WS 5, IBM AIX 6.1, Microsoft Windows Vista (32/64 bits), HP-UX 11.31, Linspire 6.0, Red Flag Linux Desktop 6.0, openSUSE 11.3, Linux Linpus Desktop 9.6, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), SunSoft Solaris SPARC Platform Edition 9, SunSoft Solaris SPARC Platform Edition 10, Red Hat Fedora 14, Red Hat Fedora 15, openSUSE 11.4, IBM AIX 7.1, Ubuntu 11.04, Linux Mint 11, SunSoft Solaris x86 11, Ubuntu 11.10, Debian GNU/Linux 6.0, Linux Mint 9, Linux Mint 10, Red Hat Enterprise Linux WS 6, Ubuntu 12.04, openSUSE 12.1, PCLinuxOS 2011.9, Linux Mint 12
Lexmark C746, C792, C9235, C950, M5163, M5170, MS710, MS711, MS811, MS812, MS817, MS818, MS823, MS911, MX711, MX717, MX718, MX810, MX811, MX812, MX910, MX911, MX912, X746, X748, X792, X925, X950, X954, XC9235, XC9245, XC9255, XC9265, XM5163, XM5170, XM7155, XM7163, XM7170, XM9145, XM9155, XM9165
Print server
Wireless
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Data Transfer Rate
72 Mbps
Remote Management Protocol
Telnet, SNMP 3, HTTP, HTTPS, TFTP, IPP 1.0, IPP 1.1, IPP 2.0
Frequency Band
2.4 GHz
1 x aerial - RP-SMA
Encryption Algorithm
128-bit WEP, 64-bit WEP, SSL, TLS, WPA2
Lexmark C746dn, C746n, C792dhe, C792dte, C9235, C950DE, C950dte, M5155, M5163, M5170, MS710dn, MS711dn, MS810de, MS810dn, MS810dtn, MS810n, MS811dn, MS811dtn, MS811n, MS812de, MS812dn, MS812dtn, MS817dn, MS817n, MS818dn, MS823dn, MS911de, MX710de, MX710dhe, MX711de, MX711dhe, MX711dthe, MX717de, MX718de, MX810de, MX810dfe, MX810dme, MX810dte, MX810dtfe, MX810dtme, MX810dtpe, MX810dxe, MX810dxfe, MX810dxme, MX810dxpe, MX811de, MX811dfe, MX811dme, MX811dpe, MX811dte, MX811dtfe, MX811dtme, MX811dtpe, MX811dxe, MX811dxfe, MX811dxme, MX811dxpe, MX812de, MX812dfe, MX812dme, MX812dte, MX812dtfe, MX812dtme, MX812dtpe, MX812dxe, MX812dxfe, MX812dxme, MX812dxpe, MX910de, MX910dte, MX910dxe, MX911de, MX911dte, MX912de, MX912dxe, X746de, X748de, X748dte, X792de, X792dtfe, X792dtme, X925de, X950DE, X950dte, X954DHE, XC9235, XC9245, XC9255, XC9265, XM5163, XM5170, XM7155, XM7155x, XM7163, XM7163x, XM7170, XM7170x, XM9145, XM9155, XM9165
