300Mbps Wireless ADSL2/2+ Modem Router The Edimax AR-7286WnA/B is a high performance router that provides full ADSL2+ capability and superb reliability as a cost-effective networking solution for homes and small businesses.
Compatible with the wireless standard 802.11n, and with advanced MIMO technology, the AR-7286WnA/B provides up to six times better data transmission rates (up to 300Mbps) and five times better coverage than a standard 802.11g/b router.
All-in-One Device The AR-7286WnA/B is a wireless N router with a built-in ADSL2/ADSL2+ modem combining a high-performance router, modem, and a switch into a single device. Save desk space, the hassle of extra cords & cables and the cost of leasing a router from your DSL service provider.
Powerful and Wide Coverage Featuring two 5dBi high-gain antennas, the AR-7286WnA/B boosts your signal to ensure extended wireless networking range. Four-Networks-in-One The AR-7286WnA/B supports multiple SSIDs for up to four wireless networks.
Lightning Protection Protected from lightning strikes to help your device avoid the damage of a tough thunderstorm.
Supports TR-069 for Remote Management The AR-7286WnA/B also supports TR-069 which is a protocol to define a common method for CPE devices to communicate with a server.
Wi-Fi Protected Setup (WPS) Wi-Fi Protected Setup is a quick and convenient method of establishing wireless connections between compatible devices. Set up a wireless network in less than a minute with just a couple of clicks of a button or easily add new Wi-Fi devices to an existing network.
Easy Setup Wizard with Built-in ISP Selector Setup the ADSL modem router using the unique and convenient multi-language setup wizard provided on the included CD-ROM or available through a web browser. Select your language and follow a few simple steps to setup the router and configure the Internet connection, password, SSID and wireless security. Additionally, the setup wizard includes a built-in ISP selector to configure your ISP settings automatically.
300 Mbps wireless ADSL2/2+ modem router
The Edimax AR-7286WnA is a high performance router that provides full ADSL2+ capability and superb reliability as a cost-effective networking solution for homes and small businesses. Compatible with the wireless standard 802.11n, and with advanced MIMO technology, the AR-7286WnA provides up to six times better data transmission rates and five times better coverage than a standard 802.11 g/b router. -
All-in-one device
The AR-7286WnA is a wireless N router with a built-in ADSL2/ADSL2+ modem combining a high-performance router, modem, and a switch into a single device. Save desk space, the hassle of extra cords and cables and the cost of leasing a router from your DSL service provider. -
Powerful and wide coverage
Featuring two 5-dBi high-gain antennas, the AR-7286WnA boosts your signal to ensure extended wireless networking range. -
Four-networks-in-one
The AR-7286WnA supports multiple SSIDs for up to four wireless networks. -
Lightning protection
Protected from lightning strikes to help your device avoid the damage of a tough thunderstorm. -
Supports TR-069 for remote management
The AR-7286WnA also supports TR-069 which is a protocol to define a common method for CPE devices to communicate with a server. -
Wi-Fi Protected Setup is a quick and convenient method of establishing wireless connections between compatible devices. Set up a wireless network in less than a minute with just a couple of clicks of a button or easily add Wi-Fi devices to an existing network. -
Easy setup wizard with built-in ISP selector
- Edimax AR-7286WnA - wireless router - DSL modem - Wi-Fi - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, ADSL2, ADSL2+
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Data Transfer Rate
- 300 Mbps
- TCP/IP, UDP/IP, ICMP/IP, ARP
- Routing Protocol
- RIP-1, RIP-2, IGMPv2, IGMP, IGMPv3
- Remote Management Protocol
- SNMP, Telnet, HTTP, TFTP, SSH
- Firewall protection, NAT support, IGMP snooping, Stateful Packet Inspection (SPI), DoS attack prevention, MAC address filtering, IP address filtering, firmware upgradable, SNTP support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), 2T2R MIMO technology
- IEEE 802.1D, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, Wi-Fi Protected Setup, UPnP
- 13.5 cm x 2.8 cm x 11.8 cm
- 187 g
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- 300 Mbps
- Routing Protocol
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- IEEE 802.1D, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, Wi-Fi Protected Setup, UPnP, FCC
- RAM
- 8 MB SDRAM
- Flash Memory
- 2 MB
- Status Indicators
- Power, WLAN, LAN, ADSL, WPS
Line Properties
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.997.1, ITU G.992.4 (G.lite.bis), ITU G.992.1 (G.DMT) Annex A, ITU G.992.3 Annex A, ITU G.992.5 Annex A, ITU G.995.1
- Max Transfer Rate
- 24 Mbps
- WAN: 1 x ADSL2+ - RJ-11 , LAN: 4 x 10Base-T/100Base-TX - RJ-45
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Gain Level
- 5 dBi
- Power Device
- External power adapter
- Cables Included
- 1 x network cable - 1 m , 2 x phone cable - 1.8 m
- Software Included
- EZmax Setup Wizard
- 13.5 cm
- 2.8 cm
- 11.8 cm
- 187 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
