The BR-6228nS V3 is a 150Mbps 5-in-1 multi-function Wi-Fi solution which supports IEEE 802.11b/g/n standards and provides significantly improved coverage with the High-gain antenna. Operating as a router, access point, range extender, Wi-Fi Bridge or WISP, the BR-6228nS V3's flexibility meets the demands of any networking applications. The smart iQ Setup wizard makes setup and installation as easy as a few clicks. Impressive performance and a competitive price make the BR-6228nS V3 a cost-effective solution for home or small office environments.
5-in-1 Wi-Fi Router, access point, range extender, Wi-Fi bridge and WISP
The BR-6228nS V3 can work as router, access point, range extender, Wi-Fi Bridge or WISP. Just configure the mode you need for your network environment using the smart iQ Setup wizard. -
Smart iQ Setup
Features iQ Setup for smart, automatic and quick installation with no CD required. -
Edimax's Revolutionary iQoS
iQoS is Edimax's solution for a quicker, easier, and more effective way to manage Internet bandwidth. While Quality of Service (QoS) functionality is a common feature in routers across the market, typically only advanced users have the knowledge required to set up the complex parameters. Edimax though has redesigned QoS with user-friendliness and accessibility in mind. A simple and intuitive user interface allows users to arrange bandwidth priority settings in just a few clicks. With iQoS, you can enjoy gaming, video streaming, VoIP applications and BT clients at the same time without the usual nightmare of lag and interruptions. An original, efficient and effective means of managing your Internet bandwidth.
- Edimax BR-6228nS V3 - wireless router - Wi-Fi - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Data Transfer Rate
- 150 Mbps
- PPTP, L2TP, IPSec, PPPoE, DHCP, DDNS
- Routing Protocol
- Static IP routing
- Firewall protection, DMZ port, DHCP support, NAT support, NAPT support, Stateful Packet Inspection (SPI), DoS attack prevention, MAC address filtering, VPN passthrough, URL filtering, IP address filtering, firmware upgradable, WISP mode, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), IPSec passthrough, reset button
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, UPnP
- 19 cm x 16.2 cm x 4.2 cm
- 230 g
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- 150 Mbps
- Routing Protocol
- Static IP routing
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, UPnP, BSMI, FCC, NCC
- RAM
- 32 MB SDRAM
- Flash Memory
- 4 MB
- Status Indicators
- Power, WAN, wireless, link/activity, Internet
- WAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 4 x 10Base-T/100Base-TX - RJ-45
Aerial
- Aerial
- External integrated
- Antenna Qty
- 1
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Software Included
- Drivers & Utilities
- 19 cm
- 16.2 cm
- 4.2 cm
- 230 g
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
