N300 Multi-Function Wi-Fi Router Three Essential Networking Tools in One
3-in-1 Router, Access Point, and Range Extender
Smart iQ Setup for smart, automatic and quick installation with no CD required
9dBi High Gain Antenna: Enhances wireless range and coverage
Guest network: Provides connectivity while isolating guests from your primary network.
Wi-Fi Protected Setup (WPS) Button: For easy one-click setup
The BR-6428nC is a 300Mbps high-speed multi-function Wi-Fi solution which supports IEEE 802.11b/g/n standards and provides significantly improved coverage with the 9dBi antenna. Operating as a router, access point or range extender, the BR-6428nC's flexibility meets the demands of any networking applications. The smart iQ Setup wizard makes setup and installation as easy as a few clicks. Impressive performance and a competitive price make the BR-6428nC a cost-effective solution for home or small office environments.
3-in-1 Router, Access Point and Range Extender
The BR-6428nC can work as router, access point or range extender. Just configure the mode you need for your network environment using the smart iQ Setup wizard and enjoy surfing the web.
Smart iQ Setup
Features iQ Setup for smart, automatic and quick installation with no CD required.
Employs two 9dBi high gain antennas to enhance wireless range and coverage, providing powerful penetration through walls and floors.
Guest Network*
Supports a guest network to provide connectivity while isolating guests from your primary network.
*Router mode only
Green Technology
Designed with the latest green technology, the BR-6428nC uses 30% less power compared to other standard 300Mbps routers.
Wireless Internet Service Provider (WISP) Connection Mode
With WISP support, the BR-6428nC is able to share an Internet connection from a wireless ISP access point and convert it into a wired or wireless network for multiple users in your home or office.
The BR-6428nC has a one-click Wi-Fi Protected Setup (WPS) button to help you set up and activate a secure wireless network in a snap.
3-in-1 router, access point and range extender
The BR-6428nC can work as router, access point or range extender. Just configure the mode you need for your network environment using the smart iQ setup wizard and enjoy surfing the web. -
Smart iQ setup
Features iQ setup for smart, automatic and quick installation with no CD required. -
9 dBi high gain antenna
Employs two 9 dBi high gain antennas to enhance wireless range and coverage, providing powerful penetration through walls and floors. -
Wireless Internet Service Provider (WISP) connection mode
With WISP support, the BR-6428nC is able to share an Internet connection from a wireless ISP access point and convert it into a wired or wireless network for multiple users in your home or office. -
- Edimax BR-6428nC - wireless router - Wi-Fi - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Data Transfer Rate
- 300 Mbps
- PPTP, L2TP, IPSec, PPPoE, DHCP, DDNS
- Routing Protocol
- Static IP routing
- Firewall protection, NAT support, NAPT support, DoS attack prevention, dynamic DNS server, MAC address filtering, VPN passthrough, URL filtering, IP address filtering, firmware upgradable, WMM support, QoS, virtual server support, WPS, dynamic IP mode
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, UPnP
- Power
- DC 5 V 1 A
- 13.5 cm x 11 cm x 2.8 cm
- 234 g
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- 300 Mbps
- Routing Protocol
- Static IP routing
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, UPnP, FCC
- RAM
- 16 MB SDRAM
- Flash Memory
- 4 MB
- Status Indicators
- Power, link/activity
- WAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 4 x 10Base-T/100Base-TX - RJ-45
Aerial
- Aerial
- External integrated
- Antenna Qty
- 2
- Gain Level
- 9 dBi
- Power Device
- External power adapter
- Voltage Required
- DC 5 V
- Electric Current Required
- 1 A
- Cables Included
- 1 x network cable
- 13.5 cm
- 11 cm
- 2.8 cm
- 234 g
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
